Hi everyone
I bought a chinese laser cutter off eBay
i thought i was buying from a uk based seller plowlive-uk
But it turned out it was a direct from china seller, after it arrived.
Anyway i got it, unpacked it, set it up & checked it worked
Then didn’t get to use it for a week or two due to work commitments
i installed coral laser & laserDRW as the booklet said
1st problem coral laser doesn’t work at all
But the laserDRW did so drew a simple txt name just to see if worked properly
i plugged in the memory stick in & tried to cut
when i tell it to cut it displays 'Need driver installing' i can’t find a driver on the stick or the disc at all (to be honest I’m not shore what the memery stick is there to do as it doesn’t seem to have much on it.
From reading some of the boards this seems like a common problem
The information I’ve found for this machine is
Device id: A0C74F11482D42F7
Mainboard: 6c6879-laser (I think)
Company/maker : Zhongpu
Model : zhongpu-460
if anyone could help it would be greatly appreciated
also laserDRW isn't that great ,could anyone tell me of a good drawing program which would work on this machine
cheers Tony
