586,640 active members*
2,817 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Toolgrinding / Toolgrinding Machines > Homebrew tool and cutter grinder open source
    May 2013
    149
    I'm thinking 25mm SHS arc welded frame,
    Worm drives from a car wiper motor,
    500w grass trimmer spindle,
    er11 to 25 say workholding,
    nema 17 or 23 steppers,
    24v psu, toshiba drives.
    It would have to be 4 axis to do a helix, or 5 axis for a ball nose cutter with relief.
    No bigger than a shoebox, maybe welding isn't even required.
    I'm sure there would be lots of interest given most people here would already have all this stuff from early experimentation.
    Thoughts? Interest?
    Wisdom results from foolishness!
    May 2013
    149
    Re: Homebrew tool and cutter grinder open source
    Moderators you can cull this one if you like, it seems stillborn.
  1. CNC tool and cutter grinder
    By charles-IPC in forum Uncategorised MetalWorking Machines
    Last Post: 03-07-2018, 10:57 AM
  2. Tool & Cutter Grinder and Wire Cutter Plans
    By newport in forum CNC Wire Foam Cutter Machines
    Last Post: 04-17-2009, 10:15 PM
  3. tool and cutter grinder prgramming!!!
    By brainlessme in forum G-Code Programing
    Last Post: 04-27-2007, 03:57 PM
  4. Walter CNC Tool and Cutter Grinder
    By valexim in forum Employment Opportunity
    Last Post: 01-21-2007, 02:31 AM
  5. Quorn Tool and Cutter Grinder
    By mtechserv in forum Toolgrinding / Toolgrinding Machines
    Last Post: 10-30-2006, 12:24 AM
