586,872 active members*
3,522 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > G71 does not remove material on finish pass
Results 1 to 17 of 17
    Jan 2013
    10
    I have a Fanuc Series 0i-TC on a Lathe
    I program the following G71 cycle with a .050 clean up pass.
    The control shows that the tool is leaving .067 for clean up pass
    Then when it takes the clean up pass, the control shows the tool going right to 1.000
    However, it does not remove any material, thus the part is .067 big.
    Any ideas would be greatly appreciated.
    I run this same program on Funac Controls 18-T. 18i-T and OT and they run perfect.
    I also run the G71 on a boring cycle and it works great.
    :1111
    (CONTOUR)
    G00G99G96S500T1212
    G50S1500
    M03
    M08
    G00X4.010Z.2
    G71U.1R.025
    G71P10Q20U.05W0.F.015
    N10G0G42X1.0
    G01Z0.0F.015
    G01Z-.7497F.015
    G03X3.75Z-5.8125R12.9412F.015
    G01X3.896Z-7.6F.015
    G01X4.0F.03
    U.05
    N20G40U.05
    G70P10Q20
    G28U0.
    M30
    2932
    Re: G71 does not remove material on finish pass
    Are the R and T values correct for Offset 12?
    Jan 2013
    10
    dcoupar,
    Thank you for your reply:
    I have a .0312 in R while using a CNMP432 insert. That seems that is incorrect as it should be .015.
    I am not familiar with the T value. Can you explain please?
    Feb 2005
    303
    If you program using radius comp, then the R value for the tool offset in this case will be .0312... The TNR for a 432 insert is 2/64" = 1/32" = .0312"
    2932
    The T value tells the control where you set the virtual tip when you touched off the tool. Most likely it should be a 3 for OD turning towards the chuck.
    Jan 2013
    10
    ghyman:
    Many Thanks. So it was set correctly. My bad. Spinning to many plates.
    dcoupar:
    Can I ask where in my the G71 program one would insert a T. I have never used a T
    Jan 2013
    10
    dcoupar:
    Are referring to the Z axis when you speak of the T?. If so yes, that is set correctly.
    Aug 2011
    2517
    you say the program runs fine on another machine so it has to be a parameter issue.
    2932
    Quote Originally Posted by Colbolt2 View Post
    ghyman:
    dcoupar:
    The 3 goes in the T column of the Geometry Offset for #12... see attached.
    Attached Thumbnails Attached Thumbnails TNRC.pdf
    Jan 2013
    10
    Thank you .
    I will double check this entry
    Jan 2013
    10
    I did check this entry.
    It was set to zero.
    I have many different size parts to run with this cycle on this machine.
    I will be setting up another size today. I will update my progress.
    What I did was run the G71 program and then wrote a additional program to come clean the part up to size.
    I will see what happens when all the entries are input correctly.
    Thanks for all your time.
    Hope I can return the favor one day.
    Jan 2013
    10
    fordav11
    Yes, this program works on 3 other Funac controls and has worked for about 17 years.
    I purchased this Femco as a back up to my TU-30 Ikegai Lathes.
    I just need it to do a secondary operation.
    I will continue to attempt get it to do what I need it to do.
    UNFORTUNATELY When I purchased the machine the machine tool salesmen told me that the machine manuals were on line.
    Not true. So I do not have any programming manuals for this machine.
    Aug 2011
    2517
    the guy wasn't lying. 0i-TC manuals are there if you look hard enough in the right place while the moon is at 30 degrees above the horizon.
    anyway you can find it attached.....
    Jan 2013
    10
    Fordave11
    I can not believe I did not find that.
    Perhaps I did not even look for it.
    Regardless, many thanks for taking time out of your day to attach that and send it to me.
    It is very much appreciated.
    Jan 2013
    10
    I have an unrelated question.
    Is there a way to get the chuck to not spin during our dry run cycles?
    *****UPDATE TO MY QUESTION******
    We just removed the M03 and the dry run cycle worked as needed.
    Jan 2013
    10
    UPDATE ON MY G71 PROGRAM
    I followed the advice from the all that responded and SUCCESS!!
    I entered the value 3 in the T section of my offsets and the program now runs the finish cycle.
    Thank you so much to all !!
    Aug 2011
    2517
    to save editing, you can use block delete on the M03 to skip it.
    /G97 S200 M3
    in CUSTOM/AUX, some machines have a STM item that will ignore any STM functions too when enabled.
  1. Cut2D Finish pass
    By FannBlade in forum Cut2D / Cut3D
    Last Post: 11-07-2013, 02:55 PM
  2. Finish pass?
    By budpage in forum CamBam
    Last Post: 07-12-2011, 06:45 PM
  3. roughing and finish pass
    By dewme5 in forum GibbsCAM
    Last Post: 05-25-2011, 07:30 PM
  4. G71 rough boring - remove final profile pass
    By Busted in forum G-Code Programing
    Last Post: 01-19-2009, 07:08 PM
  5. Finish Cutting pass.
    By Greg Maxwell in forum Mastercam
    Last Post: 11-21-2007, 06:10 PM
