586,475 active members*
3,393 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Stop machine if spindle motor fails.
    Jan 2006
    33
    Question Stop machine if spindle motor fails.
    I have built a cnc with axis driven by stepper motors,the spindle is driven by a DC motor.I want to know how to stop the machine running if the spindle motor stops,Do I need to put a speed sensor on the motor shaft,if so how do I wire it up.?Eric
    Feb 2007
    4553
    Re: Stop machine if spindle motor fails.
    erkiwi,
    Assuming you are using Mach3,
    Hardware wise it would require a sensor to provide a index pulse and an available input port.
    A custom macro would then be required in order to monitor lack of spindle motion while there is g code program activity and initiate a eStop.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2006
    33
    Thanks for your help...Eric
  1. Machine stop / Spindle Stop with a Dwell
    By yaji63 in forum Fanuc
    Last Post: 02-16-2014, 06:49 PM
  2. Replies: 10
    Last Post: 12-21-2013, 09:11 PM
  3. Machine doesnt pause for spindle to stop
    By Lomach in forum LinuxCNC (formerly EMC2)
    Last Post: 07-30-2012, 09:34 PM
  4. Spindle Motor Stop
    By rweatherly in forum Mach Software (ArtSoft software)
    Last Post: 11-25-2006, 05:28 PM
