586,922 active members*
2,944 visitors online*
Results 1 to 11 of 11
    Dec 2008
    22
    Mach3 ports and pin set up need help please
    Hello everyone.I had my router running last year and a few months ago I was trying to get another motor working as a 4th axis and I ended up changing the input for the step and dir for all 3 axis.I had a picture of what it was before I changed it but now I cant find it.does anyone know what numbers to use for each axis? I did a search and I tried X-2-3 Y-4-5 Z-6-7 as well as X-1-7 Y-8-3 Z- 5-4.
    Does anyone know what numbers I should use and or is there a manual way to figure out what step and dir pin goes with each axis.Your help and suggestions are greatly appreciated
    Mar 2010
    621
    Re: Mach3 ports and pin set up need help please
    The ports and pins setup is very specific to your machine and the equipment that you are using, driver(s), steppers, rack & pinion, ball screw, etc. Without any of that pertinent information you might as well throw the dice and guess..
    The manual for Mach3 contains much of the information that you are seeking and I would suggest giving that a read and then posting back with some more specific questions that the forum can assist with.
    Adam,
    Gecko G540, Rack and Pinion Drives-X and A axis, 1/2-10 5 Start Acme-Z Axis
    4-THK HSR 25 Linear Slides, KL23H2100-35-4B, Power Supply-KL-600-48 48V
    Dec 2008
    22
    one more thing,I set the Y axis to step pin 2 and direction pin 14 and the Y axis is working but the X and Z still are not working
    Dec 2008
    22
    Does the break out board determine what pins to use? I emailed the company that I bought it from so maybe they can help. The number on the drivers is DM542 made by act motor I purchased on ebay.The motors are 287 oz bipolar motors. Here is the link to the break out board.
    Upgraded 5 Axis CNC Breakout Board Stepper Motor Driver 5V USB Cable Mach3 | eBay
    Dec 2008
    22
    Do I have to contact the company who made the breakout board to find the correct pin asignment?
    Feb 2007
    4553
    dabularach,
    Why not post a good image of the breakout board.
    That way someone may be able to identify what you have.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Dec 2008
    22
    Attachment 257334
    Here is a pic i just took
    Feb 2007
    4553
    Post Re: Mach3 ports and pin set up need help please
    Dabularach,
    Attached is a image with the pin-out diagram.
    Jeff...
    Dec 2008
    22
    Thank you
    I will try it when I get home
    Jun 2008
    562
    I may be wrong, but as I remember(I think, maybe) in the Mach folder there is a area where back up XML files are stored. You may be able to find a prior file that will get you back to where you were.
    Mike
    Dec 2008
    22
    Thanks guys I just figured out the problem. I got the Y and the Z motor is working properly but the X was giving me a problem. I found one of the wires was loose for the X motor where it went into the driver that fix the problem. Thanks for your help everyone!!
  1. switching X and Y in Mach3 Ports and Pins
    By Matt Clara in forum Mach Mill
    Last Post: 04-27-2014, 03:58 AM
  2. G201/Mach3, ports and pins setup
    By xander18 in forum Benchtop Machines
    Last Post: 05-15-2011, 07:41 PM
  3. VCR Compatible gas ports
    By ttieuli in forum MetalWork Discussion
    Last Post: 11-17-2010, 07:33 PM
  4. More on ports and pins
    By andrewbishop66 in forum Mach Software (ArtSoft software)
    Last Post: 03-09-2007, 02:05 AM
  5. SPC Ports What are your Use?
    By SMW Precision in forum Calibration / Measurement
    Last Post: 07-31-2006, 09:46 PM
