587,036 active members*
2,941 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Thin metal work holding. Super glue to the rescue...
Results 1 to 12 of 12
Hybrid View
    Mar 2011
    480
    I always dreaded milling thin metal. without a good way to fixture. It's floppy and results in horrible surface finish etc. Then I read about using superglue and a sacrificial plate. I never would have guessed it would have worked so well and without much effort. I used a scrap piece of 1/2" 6061 as the fixture plate. The piece I machined was 1/4" thick stock machined to .185" thick. I sanded both sides with 400 grit sand paper, cleaned with acetone, applied glue, and pressed in the vise for ~ 5 minutes. I ran a 2.5" face mill .02" deep at 50 IPM and stood far away from the mill in case things went bad :-). The bond was very solid and no issues at all. To release the part I used a heat gun on the face of the machined part for a few minutes that ran under cold water. The thermal contraction of the thinner material made a "pop" sound and a tap of a hammer on the back side of the fixture plate released the work piece. I can see doing a larger number of parts in a single sheet using this method without the cost/complexity of a vacuum fixture.
    Attachment 256914
    Aug 2007
    359
    Re: Thin metal work holding. Super glue to the rescue...
    Thanks for the vid!!! Part looks great!
    Don't have to be too bright to be me
    Sep 2006
    1738
    Very nice. I may have to try this...been double sided tape from HF for Carbon Fiber machining and acrylic.
    I have a great new idea for vacuum fixture I cant wait to show when completed, but this is great idea and will need to try.
    -Jason
    Nov 2007
    2151
    Slick!
    On another forum I follow some small engine builder projects and one person uses epoxy and a wood board back plate then media blast parts clean.
    This process sounds like it would be cleaner and faster, thanks for sharing!
    md
    Dec 2009
    594
    I tried the Devcon epoxy recently based on perhaps the same example, and it didn't stick to the mill scale on my HRS backing material. When I screwed the 304SS stock to the fixture the work got very hot on the thin sections (I use air blast as coolant). Aluminum would be much better for conducting heat from very thin sections I believe.
    Nov 2013
    87
    pretty cool. I have seen this used for milling knife inserts. to "dress" the fixture between parts they would just run a fly cutter across at 0 and take off all the glue that way
    Jun 2006
    3063
    Anybody tried the low melting point polymer that Tormach sells for fixturing odd-sized parts?
    Mike
    Dec 2013
    4
    Quote Originally Posted by MichaelHenry View Post
    Mike
    Im pretty sure its just 'polymorph plastic' - you can pick it up on ebay or most electronics stores (jaycar in aus). Not sure it would work well as a glue though, getting Z tolerance would be a pita, as its more like taffy than water when heated. I have heard though that hot glue (same as you use in hot glue guns) can work well...
    Mar 2012
    378
    I use a lot of double sided tape and have had very good results.
    Dec 2009
    594
    I just learned about Crystalbond 609, a thermal plastic used for fixturing PCBs that looks like a good candidate. A friend of mine did a video where he used it to fix a penny to an aluminum rod and shaved it down on the lathe. Releases with heat and can be re-used.
    Mar 2012
    378
    Thanks for that KVOM. I have recently had the need to thin down a circuit board on my surface grinder and it did a great job with double sided tape, but it came apart when I tried removing it. Looks like Crystalbond makes several types of adhesive that are perfect.
    Oct 2005
    31
    Are you using standard cyanoacrylate or is a specific superglue?
  1. Holding thin parts
    By FuriousGeorge in forum Tormach Personal CNC Mill
    Last Post: 06-19-2014, 03:32 PM
  2. Replies: 3
    Last Post: 05-14-2014, 01:42 AM
  3. Work Holding for thin materials
    By rwskinner in forum Work Fixtures / Hold-Down Solutions
    Last Post: 12-17-2013, 08:14 PM
  4. Thin plate holding
    By tjd10684 in forum MetalWork Discussion
    Last Post: 03-16-2012, 11:02 AM
  5. Work holding options to hold thin round work? .024, .046 etc
    By KyleH2 in forum MetalWork Discussion
    Last Post: 06-07-2010, 07:22 PM
