587,072 active members*
2,967 visitors online*
    Nov 2014
    Raised Edge on Laser Cut Acrylic
    My company bought a 75W Fusion 32 not too long ago and I am working on adding some jobs to the machine.
    The application I'm currently working on is using 2mm thick acrylic. The problem I'm running into is that the edges seem to develop a raised lip (on the face of the material). The lip is typically about 25 microns (per side). This application requires a flat spacer, so the lip is an issue.
    I'm currently cutting them using 17% speed and 100% power and frequency. I have my air assist around 7 PSI. I've tried cutting with and without the protective film on.
    Can anyone lend advice on creating a flatter cut?
    Oct 2007
    385
    Re: Raised Edge on Laser Cut Acrylic
    Just a thought, but I never use air assist when cutting acrylic. The air assist seems to cool the plastic too quickly. Just a thought.
    Milt
    Feb 2012
    387
    2mm acrylic, 75w, you can make a fast speed to try?
    Quote Originally Posted by ZackRR View Post
    Lucy Lee G.WEIKE LASER
    [email protected]
    Jun 2013
    45
    I've never had a problem with "lipping" on acrylic but have had a problem when I experimented with some plastics (too soft). I would try a lower power and faster speed aiming to cut with the lowest power you can.
    Air assist is to blow out the flame that results from the laser burning through material that it is cutting. To not use air assist you risk a serious fire especially with acrylic. The one time I forgot to turn on air assist when cutting acrylic and I had a fire, luckily I caught it quickly and extinguished it before it did too much damage. I always use air assist when cutting no matter what I'm cutting.
  1. Edge Lit LED acrylic
    By Jimi Nep in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-01-2012, 10:02 PM
  2. About to try carving my first Edge Lit Acrylic Sign
    By Mountaincraft in forum DIY CNC Router Table Machines
    Last Post: 03-02-2012, 06:22 PM
  3. Help - Raised edges on face of acrylic
    By DShearon in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2012, 01:06 AM
  4. edge glow acrylic
    By 1ctoolfool in forum Machine Created Art
    Last Post: 01-16-2009, 07:31 PM
  5. edge lit acrylic
    By jseiler in forum Glass, Plastic and Stone
    Last Post: 01-07-2008, 11:06 PM
