586,530 active members*
2,732 visitors online*
IndustryArena Forum > MetalWorking > Mass finishing equipment/media/strategies > Has anyone seen these anodizing blemishes before?
Results 1 to 5 of 5
    Jun 2010
    6
    Hey all. I just got some spun 7075 parts anodized and am very unhappy with the finish. Nearly all of them have these lines on them, and I'm trying to figure out what caused them. Has anybody seen anything like this before?
    Thanks!
    Mar 2012
    1
    Re: Has anyone seen these anodizing blemishes before?
    It looks like where they attached the electrical contact
    Feb 2007
    45
    Could be contact marks from the racks from anodizing. If that part doesn't have an ID hole they can put the spring loaded clips into to hold it during the process, they will have to grip it somehow from the outside. The anodized coating doesn't grow correctly where the contacts are made.
    Jul 2009
    419
    If these lines were more across rather than straight I'd have to say yes.
    I had black lines appearing on uncolored anodisation.
    I think what happened then was that I got a bit of material (10 mm rod) that had the transition between two aluminium billets within a long length of material and the lines appearing between the first billet and the next.
    If you squeeze two 25 kilo billets through a 10 mm hole you'd get quite a long transition...
    Sven
    http://www.puresven.com/?q=building-cnc-router
    Jan 2005
    15362
    Quote Originally Posted by Andy Jarosz View Post
    Thanks!
    7075 is not a good anodizing material, does your parts have a hole in them, in general it looks to be a bad job, they need stripping and redoing
    Mactec54
  1. Home Anodizing. Low Current Anodizing. 720 Rule
    By kreutz in forum Mass finishing equipment/media/strategies
    Last Post: 11-29-2019, 04:13 PM
  2. anodizing
    By pyroracing85 in forum Material Machining Solutions
    Last Post: 02-27-2008, 06:22 AM
  3. RFQ anodizing
    By bucont in forum Employment Opportunity
    Last Post: 03-22-2007, 08:14 PM
  4. Anodizing?
    By Klox in forum MetalWork Discussion
    Last Post: 05-03-2005, 06:46 PM
