586,756 active members*
8,157 visitors online*
Results 1 to 8 of 8
    Jul 2014
    39
    Panel Meter for CNC
    Hi
    I just purchased a NEW Simpson 523 0 - 15 Amp DC 4" panel meter ammeter on ebay. I just contacted the seller
    and he mentioned that there is no shunt. Does anyone know if a Simpson amp meter has the shunt built into the main
    housing. If not would it be difficult to locate one.
    Attachment 255908
    Sep 2010
    1765
    Re: Panel Meter for CNC
    likely not; it just has the face scaled/marked.
    u can test by putting current thru it: CAUTION!
    98% PROBABILITY IT IS 1MA FULL SCALE W/O THE SHUNT
    so use 1.5v battery with 1.5k ohm resistor in series on it an confirm. if was me, i would start w/ 15k or higher in case it is 0.1ma movement....
    Jun 2012
    108
    I think this is the data sheet at the link below.
    http://www.mouser.com/ds/2/370/desig...eet-275183.pdf
    24223
    It shows Iron-vane not moving coil, which usually indicates no shunt required.
    Al.
    Jun 2010
    4256
    Moving iron meter. No shunt required.
    I have such ammeters on all drives: X, Y, Z and spindle.
    Cheers
    Roger
    Dec 2005
    To me it looks like it's only the AC-meters, that's Iron-vane, i would still try the 0.1mA road first.
    Best regards Ebbe
    24223
    Another method is to use the resistance range of a volt meter, resistance range result in a small current through the measured item, if you get a small deflection, pretty much points to moving coil that requires a shunt.
    Al.
    Jul 2014
    39
    Hi
    Got my amp meter and no shunt was required.
    Thanks for the replies
  1. load meter
    By drewmeister in forum Fanuc
    Last Post: 02-04-2021, 09:37 AM
  2. Help With Dc Load Meter Led
    By dannystooblue in forum CNC Machine Related Electronics
    Last Post: 02-09-2017, 06:03 PM
  3. Hour Meter 0i-MB
    By hrhoward in forum Fanuc
    Last Post: 09-07-2012, 02:18 PM
  4. hour meter
    By cnc-king in forum HURCO
    Last Post: 04-09-2008, 03:59 AM
  5. flow meter
    By larry53 in forum Welding Brazing Soldering Sealing
    Last Post: 03-12-2007, 09:24 PM
