586,388 active members*
3,432 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > stepper and drive sizing
Results 1 to 7 of 7
    Feb 2007
    505
    Being in the process of building my second home made router and trying to size my stepper and drive for a 150 lbs gantry using 5 tpi ballscrews and llinear rail thk25.
    According to gecko formula a 150bls gantry and a wanted speed of 200 ipm /531=56 watts should keep me in stepper territory...so far so good
    The next formula is ...desired IPM xRPI / 60= RPS (revolution per sec)
    in my case 200 x 5 / 60 =16.67 RPS
    The following formula is...RPS x 200(steps) = PPS
    in my case 16.67 x 200 =3334 pps
    the statement about determining how much oz-in is needed to move and accelerate the load is not explained and they state
    that PPS x oz-in / 4506 =watt needed , yet on their examples at the very end, they arrived at a value in oz-in
    could someone clarify this ?
    Re: stepper and drive sizing
    Why is your desired speed only 200ipm, and why are you using 5tpi ballscrews?
    How big is this machine? What diameter and length are the screws?
    200ipm is quite slow for a router.
    5tpi ballscrews will require 1000rpm from your steppers to get to 200ipm. This may be difficult to achieve with larger size motors.
    Feb 2007
    505
    Feb 2007
    505
    How do you find out how much torque is required from your stepper for a 4 x 4 router using 1610 c7 ballscrew equiped with 2 hp rotor .at 100ipm
    Its a bit late for me to change to rack and pinion since I ve already bought and installed my ballscrews
    How much mechanical power do you add to do the actual wood cutting ? Is it the 40% added
    Any suggestions welcome
    You can use this calculator and work backwards to find how much torque you need to provide a given amount of force.
    Linear Force Calculator
    With a 2HP router at 100 ipm, your cutting forces will be very low, probably 10-15 lbs maximum.
    The force required for acceleration will be the most important, and depend on how fast you want to be able to accelerate.
    Feb 2007
    505
    My 1610 ballscrew is actually 10 mm lead so about 0.4 in lead. ( 2.5 TPI )
    So at 200 ipm my stepper rpm would be around 500 rpm
    As far as acceleration I need to check my setting on my first build but It was set as high
    as possible without making the stepper loose steps...
    I dont see no speed-torque curve in any of gecko documentation ...
    How much Rpm would a gecko g-723-400-4 stepper driven with a g-540 attain ?
    Thank for the link ger21,
    linear force according to calculator 320 oz in .38 in lead .8 eff. =264 lbs
    unfortunately their site is incompleted as far as motor and drive selection is concerned..
    I realize you pretty well need an engineering degree to really figure it out, but for us hobbyist trial and error
    is an expensive option. So we have to lower our expectation as far as speed is concerned with those
    rules of thumbs and short cut formulas...
    Any ideas on improving speed and choosing motor / driver would be greatly appreciated.
    Feb 2007
    505
    I ve check my Mach 3 motor tunning setting today : step per 8128 , velocity 45 , acceleration 3
    kernel speed 25000
    200 steps per turn stepper motor x 8 microstep=1600 step per turn X 5.08 turn per inch(1605 screw)=8128 step per inch
    my first build xylotex 425 in oz stepper had quite a high inductance ,over 8 mh if I remember well, my driver could only handle 24 volts
    with a safety margin , so I was hoping the g540 at 48 volts and lower inductance motor with 1610 screw would improve performance...
  1. Sizing of a Inverter Drive?
    By getrolfed in forum Phase Converters
    Last Post: 12-06-2012, 01:38 AM
  2. Sizing a Plasma Drive
    By stucaruk in forum Waterjet General Topics
    Last Post: 11-02-2009, 02:28 PM
  3. Servo Drive Sizing
    By GEMorris in forum Servo Motors / Drives
    Last Post: 07-20-2006, 01:00 AM
  4. Help with Sizing a servo drive.
    By Fabric8r in forum CNC Machine Related Electronics
    Last Post: 10-28-2005, 07:56 AM
  5. drive screw sizing
    By Dan S in forum DIY CNC Router Table Machines
    Last Post: 11-10-2003, 02:02 AM
