Hi All
i have an ikegai turning center with Fanuc 10T Machine was lost parameters i reload parameters after that machine was ok no alarm was on the screen axis was moving properly and going to zero return position.but when i give command of spindle M03Sxx then cycle start light comes on for 3 to seconds and then off spindle run afters pushing cycle start 3 to 4 seconds but not in actual rpm he takes tow to three round in C.W and stop and then moving C.C.Wand repeating this again and again.spindle motor is not going actual RPM.i was remove the belt from Motor Pully.and give command again but no result is chang anybody can help me plz
i am worried about this problem
thanks
