IH Mill Vs Knee Mill?
I just watched a video of a IH mill cutting some mild steel plate at .200 DOC at 1.5" wide. This was pretty impressive I thought, the point being that if it can cut this deep .200" is about 5mm in mild steel the would suit for a lot of DIY engineering projects.
Apart from the difference with the IH mill and a typical knee mill such a the physical size and maybe larger table travels. The IH has 2hp motor, knee mills have about 2hp to 5hp motors.
In terms of cutting power, if you slapped on a 5hp motor on the IH mill and compared it to a 5hp motor on a knee mill, will the IH mill cut as fast and as deep as the knee mill?
Surely the knee mill is much stiffer and firmer, less chatter, better accuracy etc?
My little site on MIG welding http://www.learn-how-to-weld.com/mig-welding/
