Part number 22048 is the retaining cap that holds the consumables in place. That retaining cap fits the T60 (Powermax 1000), T80 (Powermax1250) and T100 (Powermax1650) torches. If you have the T100....it will operate on a Powermax1000, 1250 and 1650. If you have the T80 it will operate on the Powermax1000 and 1250. If you have the T60, it will only operate on the Powermax1000.
It looks like there is a tag on the torch leads....that should have the torch and lead part number listed. You will also find the torch body part number etched on the torch body (gray tube above the retaining cap and below the brass mounting sleeve).
Jim Colt Hypertherm
