587,040 active members*
2,975 visitors online*
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Apr 2009
    220
    Re: Bent Ballscrews (another one)
    Ok, here is the config.xml from Mach3. Everything step low active and dir low active is set to red 'X' and the step width (Motor Tuning) is set to 5us.
    Please change the file's extension to .xml to view it better.
  2. #22
    Jun 2010
    4256
    Hood - could you take a look please? You're the expert with these.
    Cheers
    Roger
  3. #23
    Apr 2009
    220
    Hi guys, finally Marcus Freimanis told me the following:
    "The G203V should be ACTIVE HIGH, so there should be a red X on the settings in Mach3.".
    So my setting is correctly set to red 'X'
Page 2 of 2 12
  1. Bent ball screw?
    By Finnur in forum MetalWork Discussion
    Last Post: 01-06-2014, 02:12 AM
  2. bent RM1610 Chinese ballscrews
    By C_Jamison in forum Linear and Rotary Motion
    Last Post: 03-31-2013, 12:41 AM
  3. BENT SHAFT
    By Zombiestomp in forum MetalWork Discussion
    Last Post: 09-16-2012, 09:19 PM
  4. Misumi C10 ballscrews = Chinese C7 ballscrews?
    By Shalecnc in forum DIY CNC Router Table Machines
    Last Post: 08-08-2012, 08:42 AM
  5. Bent Too Much?
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 02-20-2009, 05:25 PM
