586,410 active members*
3,066 visitors online*
Page 1 of 3 123
Results 1 to 20 of 53
    Fanuc 10 t problem OT 117 error
    CNC has lost its RAM memory. I'm re-entered parameters 9000, data parameters and started the machine. Everything works ok, the machine goes into the zero point is selected tool, and no alarms. Spindle motor is the problem.
    When I try to start the engine, typed for example s300 enter, immediately washed up on the screen OT117 SPINDLE OVERHEAT.
    The main motor (spindle motor) rotates very slowly and creaking.
    The same happens if I change the speed of the gear unit.
    I guess that's the problem in a wrong parameter.
    Please help.
ID:	255152Click image for larger version.
    Attachment 255154
    Aug 2007
    793
    Re: Fanuc 10 t problem OT 117 error
    is there CN3 connected to spindle amp. PCB?
    have you enetered PMC keep relay data?
Name:	spindle interface.jpg
    Encoder Spindle speed is ok. Turn the spindle by hand (hand), the display shows the speed.
    Before losing RAM cnc worked ok, so I guess there's no hardevrs error.
    Attachment 255380
    Attachment 255382
    Attachment 255384
    Attachment 255386
    Attachment 255386
    Attachment 255388
    E
    Aug 2007
    793
    make a photo of spindle driver's PCB in electrical cabinet
    Aug 2007
    793
    photos of connectors from below of PCB are needed
    Aug 2007
    793
    try parameter 5602 bit 3 (4th from the right) set to one
    Here are pictures of the drive spindle motor. There is another problem that interference can be set higher speed of 999 (S999 maximum).
    If I type through 1000, (for example s2000) throws an error (error code digits)
    Attachment 255540
    Attachment 255542
    Attachment 255544
    Aug 2007
    793
    have parameter 5602#3 fixed OT117 alarm?
    tomorrow, but today I could not see
    regards,
    here are the parameters that I entered, I tried to change the parameter 5602 and nothing happens, continuous alarm level OT 117th
    When I type M 41 or M40 on the screen prints OT 117 (SPINDLE OVERHEAT, the actual spindle speed deffers from the programed speed by
    a value which exceeds the limit set by the spindle speed fluctuation detection function.)
    Attachment 255668
    Aug 2007
    793
    how many spindles do you have?
    try 5604#3 (4th from the right) this parameter (set to one) cancels any alarm for 2nd spindle
    has one spindle, tomorrow I'll try 5604
    Attachment 255692
    Attachment 255694
Name:	ATT_1415123084134_image-173ed22eb12d0431b5bb50d7951ce38254566a4272bb1df330a8e905e79d5d3f-V.jpg
    Bosnia and Herzegovina, Sarajevo City zip code71000. What do you suggest?
    Aug 2007
    793
    do you mean, I make a work for you?
    if so, PM me
    I do not understand what the problem is, I'm just looking for help for your cnc
    Aug 2007
    793
    Quote Originally Posted by miki11 View Post
    I don't understand what did you mean?
    I just wrote a location that you know where I am, nothing more.
    best regards
    Aug 2007
    793
    spindle alarm, then address - where is connection?
    I know where from you are - it's wrote under your avatar
Page 1 of 3 123
  1. Fanuc error 998 ROM Parity Error ???
    By ED209 in forum Fanuc
    Last Post: 02-07-2022, 10:02 AM
  2. Replies: 0
    Last Post: 05-05-2013, 05:40 AM
  3. Error code problem
    By Simonic in forum Fanuc
    Last Post: 03-10-2011, 04:53 PM
  4. Bridgeport EZ Plus error problem.
    By mscales in forum Bridgeport / Hardinge Mills
    Last Post: 04-07-2009, 11:09 PM
  5. 6030 Error 17 problem
    By BigLou in forum Fadal
    Last Post: 01-31-2005, 09:42 PM
