My company has been running a 2008 Mag-Fadal 4020 for about 4 years now. The machine came equipped with only flood coolant, no thru-coolant or air blast. I noticed pretty quickly that activating the mist coolant button turned on one of the solenoid operated air valves on the bottom of the electrical cabinet, which was purposely plugged. I removed the plug and routed a 1/4" poly line up through the cable track and down to a home-built manifold connected to the coolant manifold. This gave me a really quick and easy, and programmable, air blast.
We just purchased a second machine which has thru-coolant. The thru-coolant is tied to the mist-cool button on the controller and operates using the same M07 command as the air blast on my other machine. I have two questions regarding this.
First, I know there is at least one unused air valve on the manifold behind the machine (no line connected to it). There may be others that have erroneous lines connected to them but don't do anything. How would I go about finding a way to activate that unused valve in order to mimic the air blast I have on the first machine? It should be tied to some command on the controller if it is installed on the machine, right? If not, is there any way to create a command to activate it?
Second, and slightly similar to the first, if there is a way to create a command to activate that air valve, then is there a way to change the thru-coolant to M50 like many other MTB's use and revert the M07 back to the air blast? That would allow me to run any program on either machine without changing the coolant commands. Worst case, I would have to change the M50's back to M08's on the flood-cool machine, but that wouldn't be likely to happen often.
Am I opening a can of worms I have no right to be messing with?
Any insight would be highly appreciated since I'm running a line into the machine from an air-gun right now in order to have air blast on the new machine. This is not programmable and uses a TON more air than the automatic on-off of the other machine.
