Originally Posted by
ZackRR
My company bought a 75W Fusion 32 not too long ago and I am working on adding some jobs to the machine.
The application I'm currently working on is using 2mm thick acrylic. The problem I'm running into is that the edges seem to develop a raised lip (on the face of the material). The lip is typically about 25 microns (per side). This application requires a flat spacer, so the lip is an issue.
I'm currently cutting them using 17% speed and 100% power and frequency. I have my air assist around 7 PSI. I've tried cutting with and without the protective film on.
Can anyone lend advice on creating a flatter cut?
