586,361 active members*
3,434 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > wierd tool path Bobart (V25)
    Jun 2012
    393
    I have spent quite a bit of time on this maybe one of you can see the problem. BBC file attached.
    I have closed geometry and tried other things. Looked for duplicates and arcs to spline. Optimize
    nothing helps.
    Thank You
    Don
    The time has come the woodworker said to speak of many things. 0f routers and Wood , chips and paints and stains and CNC and other things.
    Apr 2009
    3376
    Re: wierd tool path Bobart (V25)
    Don,see no file attached ?
    Jun 2012
    393
    That's odd. I will fix it. I did find the problem though. Bad vectors.
    Don
    Jun 2012
    393
    OK here is the file. The reason the file was not here is because I forgot to compress it.I did find the problem and it was to many vectors hiding under other vectors.
    I am spending a lot of time fixing. I think it will be worth it.
    Don
    Attached Files Attached Files
  1. Tool Path ( Bobart Ver 25)
    By Gallchobhair in forum BobCad-Cam
    Last Post: 04-01-2014, 07:01 PM
  2. tool size concept- tool path generated vs gcode
    By kjl-pdx in forum Mach Mill
    Last Post: 03-12-2013, 07:25 AM
  3. CAM: Tool path generation for ATC Automatic Tool Changer
    By S.Seveelavanan in forum Uncategorised CAM Discussion
    Last Post: 08-09-2012, 04:45 PM
  4. Replies: 3
    Last Post: 10-07-2011, 05:45 PM
  5. BobArt Tool Path
    By JohnLucas in forum BobCad-Cam
    Last Post: 12-21-2010, 08:23 PM
