586,395 active members*
2,893 visitors online*
    Jun 2012
    35
    Heeks 1.0 default language
    Hi, I'm trying the trial version of the new HeeksCAD (v1.0), which, IMHO seems GREAT so far, however, my only down side is that since my computer is in Spanish, the GUI is set to Spanish as default and to be honest, it's terribly translated.
    Any way I can set the language to English? I tried looking in the options menu and others but couldn't find any way of changing this.
    Meanwhile, I set my computers default language to English to solve the problem, but that doesn't seem right, and I'm not sure how it will affect other programs.
    Thanks for any help.
    Alfredo
    Aug 2012
    14
    Re: Heeks 1.0 default language
    Your language settings is doing nothing except setting an environment variable ($LANG on most systems) that is inherited by other programs.
    It is possible to start a program with an environment variable other than the system's setting.
    Try running (from bash)
    LANG=en_US.UTF-8 heekscad
    or
    LANG=C heekscad
    If that works, you can create a script or am alias that starts heekscad the way you like it.
    Edit:
    Since it's in the open-source forum and you did not specify which OS you were using, I assumed it's Linux.
    Jun 2012
    35
    Hi, thanks for your answer.
    Yeah, sorry, my mistake,I forgot to mention that this happens in Windows XP, I tried it yesterday in my Ubuntu Lucid install and it works as expected, so I will probably continue to use it in Linux
    Thanks anyway for your help, have a nice day
  1. V25 - can you default to Coolant Off?
    By mcphill in forum BobCad-Cam
    Last Post: 07-29-2013, 11:16 PM
  2. TL-1 RPM default
    By missinglink in forum Haas Lathes
    Last Post: 06-14-2013, 02:36 PM
  3. CNC default setting
    By Bisorcam in forum Mastercam
    Last Post: 04-08-2012, 09:46 PM
  4. Spindle default at 250
    By cuttingedgepart in forum Tormach Personal CNC Mill
    Last Post: 10-23-2010, 02:57 AM
  5. V8 default values
    By mjp in forum Mastercam
    Last Post: 01-01-2009, 03:22 PM
