586,133 active members*
3,980 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Operating chuck in M0 mode 18i-TB Lathe??
    Mar 2007
    43
    Need to know witch parameter to change so the controll let me operate the chuck in M0 mode.
    2932
    Re: Operating chuck in M0 mode 18i-TB Lathe??
    This may be controlled in the Keep Relays. What make/model of machine is it?
    Mar 2007
    43
    The machine is a Alextech Viper 3000 YMS 2007modell
    Aug 2011
    2517
    that function is set by the MTB using the PMC and ladder. you may be able to change a PMC parameter but you will need the MTB manuals for your machine to find it.
    if you are operating it manually you can just press reset, operate the chuck then press start to continue.
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. Replies: 13
    Last Post: 09-28-2015, 05:04 PM
  3. Replies: 8
    Last Post: 04-18-2014, 02:03 PM
  4. still more Vertical Lathe fun -- G96 CSS mode
    By Scott_M in forum Tormach Personal CNC Mill
    Last Post: 09-15-2011, 02:57 AM
  5. Just got CNC Lathe...Operating question.
    By xavier2nd in forum Uncategorised MetalWorking Machines
    Last Post: 09-01-2010, 06:02 AM
