586,357 active members*
3,471 visitors online*
IndustryArena Forum > CAD Software > ViaCad / Shark > ViaCad v9 Change Snaps Text Color ?
    May 2011
    92
    Question ViaCad v9 Change Snaps Text Color ?
    I can barely see the snaps in 3D. Theyre small white against a gray model.
    The "manual" says snaps text color and transparency can be changed.
    Yet under Preferences > Snaps there is no way to change.
    Any other way to change snaps test color, transparency and size ?
    Sep 2008
    140
    Re: ViaCad v9 Change Snaps Text Color ?
    If ViaCad v9 is the same as SharkFX, Snaps text color and transparency changing is a Mac only option.
    Are you using Windows or Mac?
    Larry
    May 2011
    92
    PC. The model is shaded gray. White Snaps text disappear against this shading.
    Changed the model color shading to more white. The snaps automatically changed to black. Better, but still very small.
    What screen resolution is used ?
  1. VIACAD: Text Lines Help
    By NorthridgeFab in forum Uncategorised CAD Discussion
    Last Post: 01-21-2012, 05:42 AM
  2. Adding text/color after anodizing
    By Luis Van Damme in forum MetalWork Discussion
    Last Post: 08-25-2011, 10:57 PM
  3. Change color of a surface?
    By Hoverflyer.mk2 in forum Mastercam
    Last Post: 01-12-2011, 05:58 AM
  4. How do I make different color text?
    By chippah in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-08-2008, 06:17 PM
  5. change color
    By weirdharold in forum Mastercam
    Last Post: 02-07-2008, 04:00 PM
