586,966 active members*
2,914 visitors online*
    Dec 2010
    34
    Question Trying to find Modbus commands for Modbus access in VB scripts
    Hello
    I have sucessfully added a swappable 3D printer head to my DIY router and have printed parts. I am now working on a modified screenset for this adaptation. I am using Automation Direct's Solo temp controllers for the extruder and build table I have programmed USER DRO's to read temps and Read/Write set points as well as User LED's to indicate when temps are within limits using the Modbus protocal and Mach3 Brains.
    My next steps are
    1.The ability enable/disable the temp controllers by pressing a screen button. The button would set a bit in the controller's register to stop or start the output.
    2. The ability enable/disable the temp controllers with an M-Code within a program.
    3. The ability to change the temp setpoints with an M-Code within a program.
    4. The ability to have the program wait (Dwell -I think) until the temps are within range.
    I am new to the VB script writing and am looking for any pointers or examples that can help me in my endevor. I have been reading the docs on the Artsoft Web site and have started writing code but I have been searching for VB script commands that can directly access Modbus addresses and have had very little success.
    Dec 2010
    34
    Re: Trying to find Modbus commands for Modbus access in VB scripts
    Update:
    I completed the first rendition of my new 3D print screen. Nothing fancy just functional. Since I use Slic3er to generate the G code, I am writing custom M codes to operate the temp controllers that match Slic3rs output. So far I figured out how to use M104 and M140 to change the set point values. Next up, write the M109 and M190 to pause the program until temp is reached. I am still stuck on Modbus scripting. These controllers have a Run/Stop bit to run the output rather than just turning it off via relay. I would like to use a screen button for this. Any ideas in this direction would be a great help.
    Did you read the info in this manual, starting at page 103?
    http://www.machsupport.com/wp-conten...o_Prog_Ref.pdf
    Not sure if that helps, as I have no Modbus experience.
    Dec 2010
    34
    Thanks for the responce. Yes I am working with this manual and experimenting with the commands. It looks like what I need but not much info to go on. I have sucessfully connected to the temp controllers and have started the custom M codes. So far I can read the process temps to a USER DRO and set the setpoints with the DRO using Brains and have been able to adjust temp set point with M Codes using macros. The last peice of this puzzle is to turn on and off the output and access the auto tune feature of the temp controllers with macros. I am learning a lot and I am sure i will stumble accross something that will work soon.
    By the way, I use your 2010 screen for all my router work. The automated tool touch off macros have made my life much easier. Thanks for the great work.
  1. Need help with ModBus
    By jharvey407 in forum Mach Software (ArtSoft software)
    Last Post: 03-22-2015, 06:51 PM
  2. modbus tcp
    By fishin_fl in forum Spindles / VFD
    Last Post: 08-24-2013, 03:37 AM
  3. MODBUS
    By cncbpt in forum Screen Layouts, Post Processors & Misc
    Last Post: 02-07-2013, 06:24 PM
  4. USB Modbus I/O Using PIC
    By rdhopkins in forum PIC Programing / Design
    Last Post: 05-03-2012, 01:23 AM
  5. Modbus and the PIC
    By Al_The_Man in forum PIC Programing / Design
    Last Post: 01-30-2012, 04:51 PM
