586,308 active members*
3,580 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > How to read controller name?
Results 1 to 7 of 7
    Aug 2011
    419
    Can i read control unit via a variable or parameter? ( 5020L, 700M , P200L etc. )
    Mar 2009
    1982
    Re: How to read controller name?
    very good idea. In case if someone replaced the OSP suddenly, the part program can recognise it and salute the operator :-)
    Apr 2009
    1262
    Not that I'm aware of. However some spec codes do reveal info about the control so that would be possible to check. What are you trying to do?
    Aug 2011
    419
    For use some special codes for all controllers don't need write different program.
    Aug 2011
    2517
    most of the Okuma controllers are compatible in some way. you can put a simple program with the exact same code into most Okuma machines of the same type and it will work (just like Fanuc is also compatible with any Fanuc controller for the most part). there isn't any known way to identify the controller via a command or variable.
    Mar 2009
    1982
    I would check the specification code for that. The same model could have through spindle air blow for instance, o could not have it.
    Or, the parts catcher for lathe - depends on the specification, not on model.
    Aug 2011
    2517
    specification/options can be different but even with a list of options the model control or machine would not be known. the G/M codes that are used are exactly the same. For example G141 means right chuck work and that code is universal on all twin spindle Okumas like LT/Macturn/Multus etc. Some models have different controls (i.e. Macturn can have OSP-P100L, OSP-P200L or OSP-P300L). So checking the code or specification to determine the control model is not possible, and there aren't any known variables like a control model number so the conclusion is its impossible to check a machine or controller model based on the program code or a variable. Program that runs on Macturn with OSP-P100L will also run on Macturn with OSP-P300L..... assuming they have same spec/options, programs are compatible across different controls and machines.
  1. DRO read out.............
    By cnc Rookie in forum Bridgeport / Hardinge Mills
    Last Post: 07-30-2014, 06:20 AM
  2. How to read a IGS with vb.net/C#?
    By dneisler in forum OpenSource Software
    Last Post: 03-23-2010, 09:25 AM
  3. V21 won't read Mastercam DXF
    By kvom in forum BobCad-Cam
    Last Post: 02-11-2010, 07:33 AM
  4. 10T-F READ READ READ READ READ READ
    By dcoupar in forum Fanuc
    Last Post: 03-27-2008, 11:39 PM
  5. Must Read for All
    By CBNDude in forum News Announcements
    Last Post: 07-22-2005, 03:14 AM
