586,356 active members*
3,030 visitors online*
Thread: G112
Results 1 to 7 of 7
    Apr 2007
    47
    G112
    Hey
    I am new to using G112. Before crashing a machine..... I was hoping I could get some feedback on some code so maybe I can have a little confidence when running it. I need to make a round hub that is 6.3125mm off of center. The hub itself is 25.35mm in dia. I am hoping to do this by milling it using G112.
    Any input would be greatly appreciated since this will be my first shot at using it. I am also not sure if i have to double X values
    Would this work?
    G112
    G98G1G42X37.975C0.0F1000.0
    G3C12.675X12.625R12.675
    G3C0.0X-12.725R12.675
    G3C-12.675X12.625R12.675
    G3C0.0X37.975R12.675
    G1X50.0
    G1G40X62.0
    G113
    Apr 2007
    47
    Re: G112
    Anyone?
    Jan 2009
    103
    Re: G112
    Looks like the code will work but I would use a Line-Arc lead-in/out for rad. comp. Also you could
    use a single line for the boss instead of quadrants:
    lead-in
    G3X37.975C0.0I-12.675
    lead-out
    If you adjust your Work Offset to run the routine in front of the part you can verify if the code works
    without risking making scrap.
    hope that helps
    Apr 2007
    47
    Re: G112
    Thanks for the reply mcode and thanks for the ideas!! seems like now the job is put off for another week but I am definitely excited to try it out.
    Aug 2012
    3
    Re: G112
    Feb 2024
    2
    Re: G112
    It goes by the name of the Walgreens Customer Satisfaction Survey as well. It is primarily set up to find out what the customers think about the offered goods and services. You must go to the official https://walgreensreceiptsurvey.site/ website in order to take part in the poll. The company's product and service offerings are expanded via the utilization of consumer feedback. All that is required of you is sincere input. We have included the comprehensive instructions as well as the guidelines and prerequisites for the survey for your convenience. Just have a look at them before completing the survey to determine the level of satisfaction among the customers.
    Feb 2024
    Re: G112
    Your X values look fine. Since you're using radius values for circular interpolation (geometry dash lite), you don't need to double the X values.
  1. G112
    By sandrewb in forum MetalWork Discussion
    Last Post: 10-27-2014, 02:06 PM
  2. Star SR20R G112 HELP
    By micky316 in forum CNC Swiss Screw Machines
    Last Post: 04-06-2012, 09:13 AM
  3. G112 for Okuma OSP700M
    By mobile61 in forum Okuma
    Last Post: 07-06-2010, 07:25 PM
  4. G112 NEED HELP TURNING ON PARAM
    By INXS in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-28-2008, 08:48 PM
  5. G112
    By CatCAD in forum G-Code Programing
    Last Post: 12-04-2006, 11:12 PM
