Originally Posted by
SCzEngrgGroup
I've already explained, several times, based on the actual internal workings of the 1E, why I believe you've gotten away with running as you have. But you have never bothered to address a single one of my points. "It works for me" is not proof. Unless you KNOW your actual spindle speed, you have no proof you're really running at 100% feed. You only know what you've commanded, and what you've gotten away with. You have not explained WHY the CNC tappers include the warning "CAUTION: Do not exceed the 100% feedrate" in the manual, or why there are no CNC programming guidelines given for the E-series heads. Surely you can understand that, in your case, if the spindle runs slower than commanded, you WOULD be violating this rule, and proving my point? If you're right, WHY is this warning even in the manual?
Tell you what - Why don't you "put your money where your mouth is", and prove me wrong, with a simple video - First, MEASURE your spindle speed, and prove that you really are feeding at 100%, relative to the spindle speed. I'm betting you'll find your spindle, purely by luck, happens to run exactly at, or more likely faster, than commanded, and NOT slower. Then prove me wrong by either slowing your spindle by 10%, or speeding up your feed by 10%, and show that the tap magically doesn't break when the spindle tries it shove it through the workpiece faster than it wants to go. Or, even simply explain to us all where my logic is wrong, and what mechanism in the Procunier head could possibly allow it to "absorb" excess spindle travel caused by a slow spindle/fast feed, once the clutch has fully engaged. In the absence of either of those, you really haven't proven you are running safely at 100% feed, rather than lucking out because your spindle runs slightly faster than commanded as I have postulated.
Do that, and I'll happily admit I'm wrong, and you're right, as I will have learned something.
Regards,
Ray L.
