586,358 active members*
3,613 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Snapping taps with a Procunier on the Series 3
Page 6 of 6 456
Results 101 to 107 of 107
  1. #101
    Dec 2013
    290
    Re: Snapping taps with a Procunier on the Series 3
    Being these machines do not have spindle encoders, it would probably be a good idea to use a RPM gauge with out a load, adjust the program, then run it on a scrap piece while tapping a hole and watch the RPM's, adjust again if needed.
    I have a RF45, but they have simliar quirks of a Tormach. I find that my machines RPM will vary across the board. One of these days I should make a chart, mapping the input RPM vs actual RPM.
  2. #102
    Jun 2005
    656
    I have found that measuring with a cheapy optical tach and bit of reflective tape on the spindle, that the RPM varies 10-20 RPM from the same commanded value even without load. I can't say if that's the tach or the spindle control, but something to think about.
    Of course +/-10 RPM when tapping say a 32 TPI hole 1/2" deep at 500 RPM will end up being pretty minimal anyway.
  3. #103
    7063
    The magnitude, and direction, of spindle speed error can vary greatly from one machine to the next. The most common means of speed control is an analog control voltage, generated by a PWM-to voltage circuit or a Step-Pulse to voltage circuit, both of which typical have significant non-linearities. For some, those non-linearities are quite significant. The other, less common but better, means used in some VFD-driven spindles is direct RS-485 communications with the VFD, which will typically be more accurate, but can still be off by as much as 5%, especially at very low speeds.
    Again, even a 10% error is no problem at all when tapping with the (more common) Chinese or Tapmatic heads. The Chinese head I have has enough over-travel to tolerate the spindle running as much as 30% slow. It is only the (relatively less common) Procunier that is sensitive, and then only to a slow spindle. A fast spindle will work just fine with all three. So, anyone NOT using a Procunier can safely assume the actual speed is equal to the commanded speed, and is unlikely to ever have a problem. I can't think of any other condition (apart from rigid tapping which few hobby machines do) where having precise spindle speed is at all necessary.
    Ray L.
  4. #104
    Sep 2012
    1543
    Tomorrow at 10AM Ray owes me a beer
  5. #105
    Jul 2004
    1424
    Quote Originally Posted by BAMCNC.COM View Post
    What, new video on tapping coming out on your channel? Going to break a few taps as a demonstration?
    Tim
  6. #106
    7063
    Your PM box is full....
  7. #107
    Sep 2012
    1543
    You were right Tmarks.. the greatest post of all time... vanished. I'll step out of this thread now...
Page 6 of 6 456
  1. Procunier
    By Don Clement in forum Tormach Personal CNC Mill
    Last Post: 10-21-2014, 06:13 PM
  2. Multi-tap procunier head?
    By krakenatwork in forum Uncategorised MetalWorking Machines
    Last Post: 06-09-2013, 11:15 PM
  3. Thinking of buying a Procunier Tru-tap, any advice?
    By molomfg in forum CNC Tooling
    Last Post: 03-29-2013, 05:13 PM
  4. Procunier tension compression tapping head
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 09-07-2011, 02:58 AM
  5. Heat treated 17-4 PH snapping taps
    By eject_21 in forum MetalWork Discussion
    Last Post: 04-15-2007, 03:41 AM
