The max size limit on using form taps with the Procunier 1E in aluminum is #6, M3.5 http://www.rockford-ettco.com/Downlo...1000-23000.pdf With my Procunier 1E on blind holes in aluminum I use form taps for sizes less than #6 and spiral flute cutting taps in sizes #8 to 1/4. BTW with my Procunier in the Tormach I use 100% feed, no dwell, 200% feed retracting and don't break taps unless making a mistake like forgetting to reset the feedoveride. Also remember to use a larger size drill for the "H" value of the tap. Each "H" value means the tap is oversize by 0.0005". For example an H5 tap is oversize by 0.0025" and the drill size must be larger accordingly. On through holes #8-1/4" in aluminum I use a spiral pointed gun tap with the Procunier 1E.
Don Clement
