586,124 active members*
3,177 visitors online*
    Jun 2012
    Pin size formula for shaft diameter size.
    Does anyone know of a formula for correctly choosing the diameter of a cross hole in a shaft to hold lets say a gear or bushing. Lets assume I have a 1" diameter shaft and I would like to put a sprocket on the shaft and use a cross pin (Roll, Straight or Taper) to hold it perfectly stationary. I have been through my Machinist's Bible and can find nothing. I would assume 25 to 30% of shaft diameter would be normal but was just assuming there must be standard table or formula out there somewhere to act as a guide.
    Thanks for any help
    Mar 2006
    2712
    Re: Pin size formula for shaft diameter size.
    I didn't find anything on pin size relative to shaft dia. either. Key/keway sizes are ~4:1 . Because a key generally has more shear length, you may want to be a little strong on the pin dia. If there is high force (torque) on the joint maybe more than 1 pin if there is enough length in the joint.
    Dick Z
    DZASTR
  1. what ballscrew size diameter to get ???please help
    By xakep4eto in forum Linear and Rotary Motion
    Last Post: 08-08-2014, 07:25 PM
  2. formula to figure size of stepper or servo motors
    By Goldhunter_2 in forum Uncategorised MetalWorking Machines
    Last Post: 11-24-2009, 03:27 PM
  3. what diameter size for ballscrew?
    By 15mgtar in forum Linear and Rotary Motion
    Last Post: 09-02-2009, 09:21 AM
  4. formula for drill size
    By cam53 in forum MetalWork Discussion
    Last Post: 11-30-2008, 07:36 PM
  5. what size shaft...........
    By Taylorm in forum MetalWork Discussion
    Last Post: 10-21-2007, 04:31 AM
