586,551 active members*
3,399 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Ballnose center cutting end mill question
Results 1 to 4 of 4
    Aug 2014
    29
    I want to use a ballnose (or ballmill) end mill to mill a groove into a part for a tube. So far, we have avoided using the end mills because of the small line the ballnose end mills leave inside the groove in the center. I believe the end mills that we have are all center cutting. Will a non-center cutting ballnose end mill leave a nice smooth finish without any lines?
    Apr 2012
    40
    Re: Ballnose center cutting end mill question
    The reason that you are getting the line in the center of the groove is that even though the ballmill is centercutting, the cutting speed of a ballmill acts the same as a drill, i.e. it decreases as it approaches the center of the cutter until it is zero at the exact center, so the line that it is leaving is material that is being rubbed instead of cut.
    If you can find a cutter that has even a slight flat instead of a true ball, that could potentially solve the problem, or just polish the line out of the part.
    Sep 2008
    117
    Can you tilt the cutter at an angle instead of vertically?
    Gene
    Aug 2014
    29
    Hmmm, well, I would need to make a jig that would hold the piece at an angle...
    Thanks for your help guys
  1. Center cutting?
    By DavidhCNC in forum USA Club House
    Last Post: 10-23-2014, 12:10 AM
  2. V.12 Mill Pro Selecting center-cut VS non-center end mills.
    By countryguy in forum Dolphin CAD/CAM
    Last Post: 05-20-2014, 01:27 AM
  3. Center Cutting Indexable End mill And Indexable Drill Mills
    By CDTooling in forum News Announcements
    Last Post: 08-22-2010, 10:39 PM
  4. question on cutting an arc with a mill
    By ozmodiusnc in forum Community Club House
    Last Post: 04-13-2008, 09:21 PM
