586,609 active members*
3,659 visitors online*
    Sep 2010
    122
    Easy offset question.
    After facing my part I have the perfect zero for z. So I zero out z. I then touch the facing tool off on my manual touch block. Now, what buttons do I push (procedure do I use) to enter the offset number from the z dro so that when I manually put a new tool in (I am using collets) and touch off on the same block It will go to and start cutting at zero when I start the program?
    Jan 2009
    77
    Re: Easy offset question.
    You probably already have an answer for your question, but I've been working through some offset issues of my own and may be able to offer some insight. I believe that the appropriate technique is to first zero out the tools on your touch block with Z set to zero and it's home position. and then later touching off on the top of stock to set stock zero. Ensure that the tool that is in the holder is the one that is showing in the active tool on the screen. Once you touch off the top of stock with one tool and zero the DRO the other tools should go to the same position when you use them.
    A couple of considerations,
    1. Test each to see that it goes to the place you expect it to
    2. Make sure you activate the tool using G43 Hx (replace x with the too number you are using)
    3. Try stuff and see if what happens is what you expect (in a safe location); generally we learn more from what goes wrong than we do from what goes right.
  1. Easy part counting using tool offset page.
    By djc1965 in forum Haas Mills
    Last Post: 02-27-2012, 08:18 PM
  2. Easy Mach question
    By Scottluther in forum Machines running Mach Software
    Last Post: 12-28-2011, 03:06 AM
  3. Easy question.
    By allesg in forum G-Code Programing
    Last Post: 06-28-2010, 04:10 PM
  4. easy Newb question
    By aslatte2 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-26-2010, 11:10 PM
  5. easy to answer question
    By senor J. in forum Mach Software (ArtSoft software)
    Last Post: 01-28-2005, 01:34 AM
