586,403 active members*
2,750 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Tool offsets and Z depth
Results 1 to 3 of 3
    Dec 2013
    32
    We recently traded up our CNC machines (1986-1998 Supermax's) for a 2011 Hass VF-2SS and a soon to arrive UMC750. We want to start running parts tomorrow on the VF2 but I'm having trouble figuring out how to get my Z value. I used to measure all tools and work off a 6" block from the table surface, everything was negative. Now I have a VF2 with a Renishaw tool presetter and a probe with a broken tip. I've used the presetter and probe combo before, but with not having a probe how do I find my WPC Z?
    I'm guessing touch off my tool to the work Z, then add the tool length to the Z value?
    Thanks!
    Nov 2007
    479
    Re: Tool offsets and Z depth
    If you touch your tool on work Z, all you have to do is hit "tool offset measure" in the Z work offset page.
    Apr 2012
    90
    Jog your Z down and use a set of gage blocks to measure your Z from the table to the spindle nose. Add the height of gage blocks to your Z distance and write that number down. Now for setting your Z for the program. Just measure from where you want your Z to the table and subtract it from your Overall Z and enter that number in for your workoffset. That way you can still use the tool probe. Or you can buy just the stylus for about $150.
  1. setting the tool data and the tool offsets
    By Michael82 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-01-2022, 03:10 AM
  2. Setting tool offsets and tool change position.
    By trishbits in forum CamBam
    Last Post: 02-08-2013, 12:18 AM
  3. Thread depth and offsets
    By Lochlin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-20-2012, 08:53 PM
  4. Replies: 4
    Last Post: 02-01-2011, 03:10 PM
  5. Tool Life vs. Depth of Cut on an X3
    By Kingjamez in forum Benchtop Machines
    Last Post: 10-24-2010, 09:00 PM
