586,872 active members*
3,804 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > reviving a samutan "defective" bldc kit with a brushless RC type ESC?
Results 1 to 8 of 8
    Jun 2007
    3891
    so I had a thought. need some input as to weather is can work at all.
    ive got a novakan and its came with a samutan bldc drive and motor. the drive was crap, and blew a long time ago (everyone knows the samutan story by now id imagine). i replaced the spindle with a high speed motor spindle in the meantime.
    but I have this motor sitting there and another project requiring a motor, and was wondering, would a brushless esc with the correct voltage make it run? I know it wont have good low speed characteristics being sensorless, but it should still make it turn right?
    I don't have any esc's handy here to give it a try except one from a micro plane. 7.4v 3 amps. I don't think that's gonna even turn it (or with it?)
    anyone have any thoughts?
    Jun 2013
    1041
    Re: reviving a samutan "defective" bldc kit with a brushless RC type ESC?
    Automation technologies is selling a new version of those motors and controllers again. I don't see the drive listed as a option but it may be worth contacting them to see if they can provide just the drive for you.
    Ben
    Dec 2003
    24223
    3amps seems very low current for a RC ESC?
    Also they are typically very low voltage - High current, 10-30amps.
    You are better off looking at a A-M-C or other BLDC drive on ebay.
    Al.
    Albert E.
    Jun 2007
    3891
    3 amp is for a micro plane. motor is less than 1cm diam.
    but yeah, I was just wondering if it would "work". I am finding that as you get to bigger voltages (even just 60v), the drives become expensive to the point the industrial ones are only slightly more money. none of the sub $50 do more than 24v or so.
    Jun 2007
    3891
    Al.
    hmmm.
    so I looked at the amc drives. they are all a tad expensive for this particular motor. the cheap ebay ones seem to all be 60 or 80v dc operation.
    I was looking at vfd's that do permanent magnet motors. would this motor be compatible? or is a bldc different enough to not work. I guess they are wound differently from an ac servo.
    Dec 2003
    24223
    A BLDC motor is usually wound identical to a AC sinusoidal servo, (BLDC are used for servo's also).
    A BLDC motor has a three phase wound stator with a P.M. rotor, and timing pulses to commutate, either Hall or encoder pulse equivalent.
    A while ago I contacted Hitachi, that claimed they had a BLDC compatible VFD, they came back that the VFD would have to be custom set up for a particular motor, unfortunately.
    Incidentally modern HVAC system use a brushless P.M. ECM fan motor (Electronically Comutated Motor), but the electronics are dedicated and built into the motor itself.
    Al.
    Albert E.
    Jun 2007
    3891
    hmm.
    yeah, the cheap pm compatible vfd's seem very... not ideal. there are some nice ones with encoder feedback, but they cost $600+. they are effectively an ac servo drive.
    cant win here, haha.
    theres some temptation to try and reuse the original driver and give it a new brain, but that might be beyond my electronics abilities (it seemed to be beyond the manufacturers abilities as well!).
    Jun 2007
    3891
    oooh, found a servo drive that may work with my siemens servo motor for $100. gonna look into that. if it can work its far better than this samutan thing. the siemens will hold 6nm at 4000rpm for 2.5/10 min cycle. kinda perfect for a spindle with a 2:1 pulley.
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. Acurite MillPwr - can we customise names in the "Tool Type" table ??
    By rayg in forum Bridgeport / Hardinge Mills
    Last Post: 12-09-2013, 10:11 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 04:48 PM
  5. drive for Fanuc "red cap" brushless motors
    By jmelson in forum News Announcements
    Last Post: 07-24-2009, 04:07 AM
