586,461 active members*
4,583 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Connecting PNP inductive proximity sensors to BOB
Results 1 to 2 of 2
    Oct 2014
    1
    Hello everyone,
    I was a passive reader till now and my first post is a problem - I hope nobody minds.
    I have a set of motors, drivers and power supplies from wantai-motors, all is wired up and running fine.
    But now I'm confronted with the problem of connecting PNP-proximity-sensors (6-36Volt). I'm still pretty bad with
    electronics (you see it in the amateurish diagram).
    But could anyone say if I did something wrong? I'm so unsure about the voltage divider. I planned to supply the sensor
    with 12 Volts and then break up the voltage and current to be a logical 5V for my breakoutboard - but does it work that way?
    I don't want to fry something.
    Can somebody help me out before I try it?
    Attachment 254034
    Attachment 254032
    Many thanks
    Daniel
    Dec 2003
    24223
    Re: Connecting PNP inductive proximity sensors to BOB
    If the inputs are opto isolators with a internal series resistor set for 5v operation, you could simple measure the current the opto is set for by inputing 5vdc and measure the current, then wire a suitably calculated resistor in series from the collector to input based on the difference ~7v or just under.
    Assuming open collector prox.
    Al.
    Albert E.
  1. Helpful Tips For Using Inductive Proximity Sensors For Homing/Limits
    By SCzEngrgGroup in forum Benchtop Machines
    Last Post: 04-13-2013, 12:30 PM
  2. Inductive proximity switches
    By Skiroy in forum CNC Machine Related Electronics
    Last Post: 09-03-2011, 12:54 AM
  3. Using inductive sensors with Mach3 & C11
    By Georgie in forum CNC Machine Related Electronics
    Last Post: 05-05-2009, 11:49 PM
  4. Inductive Proximity Sensors
    By nickfox in forum CNC Machine Related Electronics
    Last Post: 09-07-2006, 03:15 AM
  5. Inductive Proximity Sensors-what are they?
    By Splint in forum CNC Machine Related Electronics
    Last Post: 08-01-2004, 11:24 PM
