586,441 active members*
4,521 visitors online*
IndustryArena Forum > CAM Software > EnRoute > No Lift Tool Pathing?
    Dec 2010
    7
    Looking for any advice regarding the following issue and thank you in advance. So I'm making signs pocketed out of .140 Melamine (at a depth of about .040) but I have a bit of a problem with the depths on a single bit. For a nice smooth finish I've been running a 1/16" Endmill across the entire sign face after hatching down most of it with significantly larger bits. The problem I have is that parts of the sign will be different depths, even though It's all the same tool path with the same tool. I know that Enroute 5 (which Im running) has no-lift tool pathing but it's only for routing offsets and mainly used in plasma cutting applications to reduce the number of on/off cycles and reduce wear. I'm wondering if anyone knows any other methods to no-lift pathing in Enroute? Obviously it will need to lift to go into the center of an "A" or an "R", etc... but if the rest of the face could be run without lift I think the signs would come out more significantly more even. The 1/16" bit at the end is only removing .005 or so of material.
    I am running Enroute 5
    MultiCam 3000 Series 5' x 10'
    Oct 2008
    23
    Re: No Lift Tool Pathing?
    Jerry, you could try turning your shapes into 3d reliefs and merging them together so Enroute sees the whole thing as one object.
  1. Newbie Pathing Problem - Tool Width?
    By tshumay in forum Uncategorised WoodWorking Machines
    Last Post: 10-20-2014, 01:34 PM
  2. Pathing issues
    By Gregore in forum MadCAM
    Last Post: 08-29-2014, 04:49 AM
  3. Pathing issues, too?
    By DB28704 in forum MadCAM
    Last Post: 08-28-2014, 05:57 PM
  4. 3D tool pathing
    By machinecrasher in forum Mastercam
    Last Post: 07-21-2011, 06:19 AM
  5. Efficient tool pathing with nesting using MCX3
    By fallacy4 in forum Mastercam
    Last Post: 05-27-2010, 02:54 PM
