586,307 active members*
3,469 visitors online*
Results 1 to 10 of 10
    Sep 2012
    5
    100W Reci laser tube dead after less than 1 hour
    Hi
    I am nearing completion of my laser engraver build, Installed a Reci Z4 100W tube, aligned mirrors and did a few test cuts on some MDF at 50% power, amp meter reading about 12ma. Everything seemed to be working perfectly I was a very happy man, gave myself a pat on the back for a job well done and shut down for the day. Next day fired the machine up again, excited to run more tests but to my horror, when I fire the laser I hear a sort of sizzling sound from the + side of the tube and the laser doesn't fire, no reading on the amp meter.
    Please help
    Feb 2012
    387
    Re: 100W Reci laser tube dead after less than 1 hour
    If you can confrim problem with laser tube ,reci can send new one to you ,
    And for our machine ,w eusually suggest to pull out the 5 line connector on laser power, to test on the 1 st reflector, if there is no lasers ,then the laser tube problem is 80% and of course ,make sure all the LED lights is on (red green, yellow)
    Lucy Lee G.WEIKE LASER
    [email protected]
    Nov 2008
    382
    mostly
    is the connection on the plus side make sure you have silicon sealed the whole area.
    greetings
    waltfl
    Sep 2012
    5
    Thanks for the reply, I haven't tried silicone but I did check the connection and replaced the crimped lug. The strange thing is that everything was working well and the next day NOTHING, not even a pink beam or a amp reading.
    Hi Darry
    We have a tech lesson to guide you found the problem and how to solve it,
    hope this can help you:
    Why The machine no laser beam
    good luck
    www.thunderlaser.com
    Sep 2012
    5
    Thanks Amy
    My power supply only has one red light which goes on when I press the test button, I hear a arcing sound from the power supply and from the tube positive side but no laser beam.
    Nov 2008
    382
    look for sparking somewhere along the positive line and the HV powersupply maybe open it up if you see a sparking there is the failure if it is on the wire put a piece of PVC tube over it if it is inside the powersupply you need a new one.
    greetings
    waltfl
    Sep 2012
    5
    Switched all the lights off and couldn't see any sparking, Will take the top off the PSU and have a look, I can definitely hear arcing from it so I'm praying that it's the power supply and not the tube to replace.
    Darryl
    Mar 2006
    58
    Hi darry,
    I had the same problem but intermitting laser, fires sometimes and doesn't fire in other times.
    Have you resolved your problem?
    Feb 2016
    381
    Red face Re: 100W Reci laser tube dead after less than 1 hour
    Lights off and test fire with tube case open if catalyst leaked away should see a faints pink glow in centre of tube at HV end, then new required tube as catalyst as seaped away happens often on long shipping or storage of cheaper tubes but Reci have a better although not faultless reputation.
    just seen date of post that had been revived
  1. 100W Reci laser tube dead after less than 1 hour
    By DarrylD in forum Australia, New Zealand Club House
    Last Post: 10-22-2014, 12:59 PM
  2. Intermittent error with otherwise functioning laser cutter (G Weike 1290, 100W RECI)
    By Basecamp in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-17-2014, 11:02 AM
  3. RECI 100w W2 laser tube - best place to buy in USA
    By stevenz2207 in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 10-06-2014, 04:41 PM
  4. What are the symptoms for co2 laser tube (RECI) dead
    By tabish_ubeid in forum Community Club House
    Last Post: 05-24-2013, 06:38 AM
  5. Reusable CO2 100W 130W 150W Laser Tube ? Replace the traditional CO2 laser tube
    By dianmanlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2013, 05:04 AM
