Hello
sorry for my poor english,
I have a dream to build a 6-9(I know the six axis is enough for me) axis CNC if possible. a combination of CNC lathe and CNC router.
This CNC have to work with both wood and metals.
[That's not likely to work too well, unless you have an extremely well-equipped factory to build it in and a crew of experienced machine designers and mechanics. Foam, plastic, wax and wood would be feasible on a shop-built design like this, metals not so much.]
I know here are very useful information related to my inquiry, but since my English is not good enough to read every things, I need your help to find my answers please!
let me explain some thing about my dream:
- my CNC router will have a 6 axis and look like this:
Attachment 253996
- it has BT series Spindle like BT30.
- I will obtain my plan and design from some paid DIY plans and combine them to make it suitable for myself.
[Which plans are those?]
- I want it to have a ATC system.
- it will work with both soft and hard material like aluminum and steel.
[It might work to some extent on aluminum if you do an excellent job of constructing it, but steel would be much more difficult.]
- and also it has some sensor like height and etc.
- my CAD/CAM/CAE software is Catia V5.
[With that software, you could come up with a nice design, but building it is another issue. You'd need a machine about that strong to build it, although it wouldn't require all those axes.]
and here are my inquiry:
What is the best PC-Based CNC control software I can use? if this software can do almost anythings instead of somethings!!! is much more better, who know what will needed in future days? * if this software can control 9 axis at least, it made me so happy
[Your best bet, as has been pointed out, is LinuxCNC. But usually machines like this run on dedicated proprietary controllers.]
I want to build the control box by myself, is there any good DIY schematic or circuit which can control all it's 6 axis and sensor and can I obtain it freely or paid? Is there any DIY plan to building Servo motor drive?
[I don't know of anybody who builds their own servo drives; it's way out the range of a normal DIY project. Wiring up 6 pre-built drivers for your 6 axes isn't as complicated, although I've never seen any published schematics for doing that. You might ask about it on the LinuxCNC forum. ]
Which specification should it have to work with metal like Iron?
Siavash
