586,399 active members*
3,189 visitors online*
    Aug 2012
    13
    odd timing belt needed
    Hello, I've got an old ESAB CM250 with a little timing type belt under the pinion gear. Having a hard time finding them. Any suppliers someone might know of? Thanks, 1
    Oct 2006
    323
    Re: odd timing belt needed
    Not knowing where you have or have not checked, but the most likely places I'm guessing you had no luck, such as McMaster Carr or Stock Drive Products?
    If no luck, is it feasible to change out with a new belt and new pulleys?
    Jan 2006
    2985
  1. Timing belt questions
    By 3Dsigns in forum Linear and Rotary Motion
    Last Post: 10-22-2012, 02:02 AM
  2. Timing Belt Dilema
    By Rover999 in forum Mechanical Calculations/Engineering Design
    Last Post: 09-23-2012, 11:36 PM
  3. timing belt instead of screw
    By Ed Williams in forum DIY CNC Router Table Machines
    Last Post: 10-28-2009, 01:27 PM
  4. bridgeport boss series maintenance manual needed for z axis timing belt change
    By ajitsingh in forum Bridgeport / Hardinge Mills
    Last Post: 11-06-2008, 04:57 PM
  5. Timing belt drive
    By jdholbrook in forum Linear and Rotary Motion
    Last Post: 04-29-2006, 09:26 AM
