I just got all the electronics to convert my g0704 to CNC. I've got everything wired up but I'm not getting any movement from the stepper motor however it is locking into place when I turn the power supply to the motor on so I know it's getting power. I think I may have an issue with my breakout board. If I measure at the parallel port directly I'm getting 5V, when I measure from the pins on the breakout board I'm getting 2V. Is that normal? If I measure while I'm jogging in mach 3 I can see the voltage change but the motor doesn't move. Does anybody know what could be going on?
