586,457 active members*
3,367 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > EDM Discussion General Topics > I have a new job in EDM-what do I need in my toolbox?
    Dec 2009
    16
    Hello,
    I have a new in EDM(my first machining job) I will start in two weeks, the shop is a prototype shop for the oil and gas industry. They make parts $90,000 and up. Any input is appreciated as I will be buying used on ebay and new on amazon. I already have a toolbox.
    Eugene
    :banana:
    Sep 2010
    72
    Re: I have a new job in EDM-what do I need in my toolbox?
    Sinker or wire?
    Dec 2009
    16
    Both
    Sep 2010
    72
    To start, you should have what every machinist (imo) should have at the very least:
    Calipers, dial or digital, 0"-6" and 0"-12"
    Outside micrometers to 3"
    Depth micrometer set, blade preferably
    Dial indicator (.0001")
    Precision squares
    Protractor
    Radius gauges
    1-2-3 blocks
    Measuring tape
    Multimeter
    Hex wrenches, standard and metric
    Wrenches, standard and metric
    Screwdrivers
    Small mallet, dead-blow, or brass hammer
    Needle file set
    "Kant-twist" clamps ... NOT c-clamps (you can never have too many Kant-twist clamps)
    For working with EDM machines:
    Particle masks ... for when your machining graphite electrodes
    Good sharp scissors and/or a lighter ... for when you need to cut wire because the machine can't or won't
    You say this is your first job in machining.
    Most of the precision measuring instruments are expensive (or at least good ones are) so don't expect to run out and buy them all at once.
    Start with the calipers and hand tools and buy the others as you can afford them.
    Dec 2009
    16
    Update on what I got so far...
    Update: :wee:
    This is what I got since start off with:
    3 Dead blow hammers 1 to 4 lbs
    brass hammer
    set of 5 ball peen hammers - use the small one once the rest not yet
    Mitutoyo Dial Caliper 8 inch - second most important tool
    Mituoyo .0005 test indicator with Noga base - most important tool
    I use both metric and standard hex wrenches depending on edm machine
    DeWalt 20 volt rachet impact driver - i use standard/metric hex sockets - they make removing machine bolts easy.
    Pass through sockets for long threads...not so useful/
    Notebook
    HP 36x calculator to figure out stuff like chords of circles. ie machining to depth on an ID.
    Magnetic LED flash light
    Angle block set - we super glue it to sides to indicate at an angle
    starrett Pocket level...very useful level.
    starrett 4 inch level...saves alot of time indicating.because of the extreme sensitivity.
  1. Toolbox
    By dtm in forum Solidworks
    Last Post: 10-06-2014, 02:49 PM
  2. Can't get bolts and nuts out of toolbox
    By Spencer myers in forum Solidworks
    Last Post: 02-03-2012, 11:46 PM
  3. Machinist ToolBox PDA
    By cncadmin in forum MetalWork Discussion
    Last Post: 02-10-2005, 07:02 PM
