586,384 active members*
3,642 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Puma 10HC parameter problem
    Dec 2012
    5
    Hello all.
    We just bought a used Puma 10HC -95 Fanuc 0T-C
    The problem we have is that the machine was sitting with no battery at the seller.
    We got a parameter list with the machin. But it is not from my machine!!
    Wehere can i get a copy of the parameters to my model? Tryed the Swedish reseller but NO. Thay did not want to help.
    serial PH100479
    my problem is that if i make a program that turns a bit into different diameters. say 20mm, 30mm, and 40mm only one of them is right. The encoder parameter must be wrong. X amaount of puls / mm
    But i cant find what parameter it is.
    Feb 2013
    788
    Re: Puma 10HC parameter problem
    Quote Originally Posted by Sastrom View Post
    Did you get a list for a generic Puma10HC w/0TC? ...or for a different machine, entirely?
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Dec 2012
    5
    I do not think its fot a Puma 10hc
    the serial on the paramerer list is way of.
    I will see if thr machine specs is printed on the parameter list
    Dec 2012
    5
    The Danish reseller emailed me the copys of the parameters to my mashine.
    Dec 2012
    5
    Anyone know howto transfer the paramers to the machine?
    The files, 2, are in .tap format
    Dec 2012
    5
    Well i'll answer myself.
    Fix the communication parameter manualy.
    The set PWE to 1, go to parameter setting and pusch EOB and Input reading from DNC starts
    Same for diagnose parameters but you should be in diagnose settings and pusch EOB and Input
  1. Daewoo PUMA 8HC Parameter required
    By usmanfati in forum Daewoo/Doosan
    Last Post: 03-13-2023, 10:09 PM
  2. daewoo puma 10hc
    By j.lyons in forum Daewoo/Doosan
    Last Post: 04-24-2013, 01:59 AM
  3. Deawoo Puma 10hc alarm 27
    By RP Jr. in forum Daewoo/Doosan
    Last Post: 07-16-2012, 06:31 PM
  4. OLD PUMA 6S, 10HC
    By oleggch in forum Daewoo/Doosan
    Last Post: 09-15-2011, 01:44 PM
  5. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
