586,728 active members*
2,583 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Lofting - Trying to make aircraft exhaust stack..
Results 1 to 8 of 8
    673
    I've modeled lots of mechanical parts, but nothing with surfaces/curves so far. Trying to model an aircraft exhaust stack that starts with an oval, turns 90 degrees, and ends with an oval 90 degrees to the first. I tried lofting with a guide curve, but I don't want a twist, just want it to flatten out like the pic. I'm not sure how to draw the guide curves. What's best practice for this sort of part? With a tip or 2, I can then make lots of stuff I'd like to.
    Feb 2009
    311
    Re: Lofting - Trying to make aircraft exhaust stack..
    Is this more like what you're looking for? Lofting can be tricky, and sometimes I just have to mess with it for awhile to get what I'm looking for.
    C|
    Jun 2008
    562
    Try something like this. not true oval but you will get the idea.
    OOPS, Cygnus beat to it. Mine is slightly different
    Mike
    Feb 2009
    311
    Quote Originally Posted by Mike 1948 View Post
    Mike
    I like yours better actually!
    C|
    Jan 2006
    2985
    Don't be afraid to add a third (or fourth, fifth, ...) profile to your loft to get what you want. As stated, it can sometimes be tricky and you just have to mess around with it a bit.
    Jun 2008
    562
    You can also add another guide curve to control the backside contour. I used only one on my part on the front side
    Mike.
    673
    Whups, dupe post
    673
    Thanks for the help! I see I almost had it, just needed more guide curves! Thanks to you both, I really appreciate it!
  1. Have trouble lofting a hex into a circle.
    By GM81 in forum Mastercam
    Last Post: 09-05-2013, 04:51 PM
  2. Cant make sense of this light stack wiring
    By Skiroy in forum CNC Machine Related Electronics
    Last Post: 08-25-2011, 03:49 AM
  3. Lofting is killing me
    By CuttersCov in forum Solidworks
    Last Post: 04-12-2009, 10:00 PM
  4. Does TurboCAD Deluxe V14 offer lofting?
    By SteveC68 in forum Uncategorised CAM Discussion
    Last Post: 11-27-2007, 05:15 AM
