Re: VMC Mill Discussion
Originally Posted by
G59
You also criticize a concept that you have no idea what the dimensions are other than what I said the work envelope would be.
You also have no idea how or even what it's made of, or how heavy it is.
aarggh, arm chair engineering is Ok, but only if you can bring constructive criticism into it.
Which is why I had the word "surely" at the end, to make it clear it was an opinion that was questioning the points raised!
You can laugh all you want, I wasn't trying to offend, I simply based my remarks on what I could see, and what I thought was common sense regarding flex and forces based on my own experiences and observations.
If I'm wrong, then good, it's an interesting design, and until you posted it and I subsequently googled it, it would have never occurred to to me to make a travelling column mill, as it still seems to me a fixed column machine would offer better machining for a set price range against a comparably priced moving column machine? This argument seems not at all different to the fixed gantry/moving table arguments, in that everyone seems to concur the moving table is by far the easiest to build, and offers the most rigidity, so I'm still unsure how in a moving column mill the theory is reversed, and a moving table is the same or less rigid than a moving column mill, unless the moving column mill requires far more design, costs, and materials to compensate for that?
I also don't own a Tormach, I have a 750kg knee mill, but do agree 1.5HP is possibly a joke for a machine that size, although many owners seem to have done exceptionally well with them, so it must more than suit a lot of people, but that's a purely personal choice. I'm very happy with my simple 3HP mill myself.
Regarding linear rails and lifting, we actually do see this here on the zone heaps, whenever someone builds a Z too high, or a frame not solid enough, etc, and it invariably ends up with lifting and looseness in the assembly. So I thought my question there was valid, if it wasn't, then so sorry.
cheers, Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
