586,345 active members*
3,002 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > (9178 Excessive Following error)
Results 1 to 15 of 15
    Oct 2014
    15
    Good Morning.
    Dear friend you've been seeing in the forum accompanies the users of Cincinnati.
    I have an Arrow 500 here in Brazil and I'm about 02 months with this alarm
    Alarm Cincinnati Arrow 500 (9178 Excessive Following error)
    I need help.
    If you need anything I can help also have enough information.
    Thank you
    Dec 2006
    584
    Re: (9178 Excessive Following error)
    What control do you have?????
    Mike cncmachineservices (dot) com
    Oct 2014
    15
    Hi.
    Control techniques
    with drives
    MAXAX 100 for X and Y
    MAXAX 200 for Z
    Recalling that the alarm is in the Z axis
    Regards
    Dec 2006
    584
    The problem could be that the Z axis brake is on ( no voltage going to the brake to release it) and this is causing a drag on the axis drive. You should also look at the axis gain, it may be set to low. This error means that the axis is not keeping up with the control. This is a parameter in the control and it has a window that if the slide exceeds the amount it puts an alarm. Look at the axis and see if it has a mechanical bind. If it does not then look at the axis drive and gain for proper adjustment.
    Oct 2014
    15
    okay,
    as the brake'll check more carefully though as the mechanics did the maintenance shaft in a company that specializes in this subject without slack ok now I'm seeing if there is a need to replace both bearings the Z axis
    An interesting detail when disassemble the spindle motor and turn on the machine I refer to it do a test with rapid advances as G0 program the engine operate normally without giving the alarm summarizing the alarm only occurs when the load of the head exerts tensions for braking.
    I am also trying a test with another younger Control Techniques but have not yet had success model drive the drive is a Unidrive model.
    Regards
    Dec 2006
    584
    Are you saying that the thrust bearings for the Z axis are bad or is the brake not releasing ???
    Oct 2014
    15
    no
    the bearings are ok
    the Z-axis drive is new.
    Put a Control Techniques Unidrive model to replace the 200 MAXAX
    We need to optimize the shaft
    difficulties to set the parameters
    Jeferson
    Dec 2006
    584
    I am not sure what you mean by "We need to optimize the shaft difficulties to set the parameters." can you be more specific. Are you getting the same alarm???
    Oct 2014
    15
    Caro amigo,
    Descobri através de Rob Varney que o meu transformador estava ligado errado ,
    mas o meu problema Alarm 9178 Excessive folling error ainda continua,
    estamos tentando consertar a unidade MAXAX 200 do eixo Z para testar apos a correção do tranformador .
    Dear Friend,
    I have found by Rob Varney that my transformer was connected wrong,
    but my problem Alarm 9178 Excessive folling error still continues,
    we are trying to fix the MAXAX 200 drive the Z axis to test after the correction of the transformer.
    Oct 2014
    15
    The problem was resolved the error was in the misalignment of Resolver , which was corrected by a specialist.
    Oct 2014
    15
    Dear Friend.
    Previously we exchanged information and decided that my problem was Solve the Z-axis servo motor out of position
    Now it's alright
    the machine is already running but now I am with a doubt when I generate a program in software and perform via dnc when the outline tool set in corners or curves the machine makes short breaks
    need to know what command to soften the prog
    Dec 2006
    584
    You need to adjust the axis gain and balance of the servo's to match each other or slow down the feed rate.
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Oct 2014
    15
    okay,
    The gain this correct
    How do I reduce the speed?
    Do you have CT FNC manual "Control Techniques" CPS 3500?
    I need data processing speed information / signals.
    To make a correct Retrofitting of servo motors and transmissions.
    I am interested in selling the original control, "CT FNC" if you are interested let.
    MAXAX 100 units and 200 and control techniques Servant
    all this running.
    I have a control panel / mother / memory module / reservation of all this for venda.oard / memory module / book this all for sale.
    Regards
    Dear friend
    Click Control techniques
    Dec 2006
    584
    The problem that you may be having is long block processing time if you are cutting a mold in 3 axis movement. You may need to reduce the feed rate to allow the older control to process each block and move to the next block. Did you retrofit the machine with a new control, how did that go??
  1. Excessive Way Oil Consumption
    By JoBwan in forum Haas Mills
    Last Post: 04-18-2011, 04:54 PM
  2. Replies: 3
    Last Post: 02-09-2011, 03:41 AM
  3. Arrow 500 Z axis excessive following error
    By Slick27 in forum Cincinnati CNC
    Last Post: 01-12-2011, 11:28 PM
  4. Arrow 750 Error 9178
    By ivanfed in forum Cincinnati CNC
    Last Post: 09-09-2009, 09:36 AM
  5. Excessive oil use
    By billiards in forum HURCO
    Last Post: 08-14-2008, 03:05 AM
