587,019 active members*
3,990 visitors online*
Results 1 to 5 of 5
    Aug 2014
    4
    Parallel Port in not responding with MACH3
    hi all;
    i'm new on CNC and Mach 3 software , but I've done alot of projects on Parallel port using visual basic.
    all pins of my parallel port works perfectly as expected with all software except Mach 3
    I've assigned PIN 2 and PIN 3 for step and Dir of x-axis respectively. by monitoring parallel port i can see that these two pins does not respond at all. instead, non related pins starts blinking !
    am i missing something ?
    please i'm looking forward to see your comments
    Apr 2004
    5742
    Re: Parallel Port in not responding with MACH3
    Have you gone into BIOS and made sure that the LPT ports are configured as EPP?
    Andrew Werby
    Website
    35538
    What operating system are you using? Do you have the correct port address in Mach3?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2012
    141
    Is it a fresh install on the pc ? I swopped a drive over from an older pc into a new pc with mach3 and it didn't work. Had to reinstall ....
    Jan 2007
    235
    I would check the parrallel cable and make sure the pins are the same on both ends. "Straight through" parrallel cable.
  1. Mach3 parallel port outputs
    By Drools in forum Mach Software (ArtSoft software)
    Last Post: 09-10-2012, 01:12 AM
  2. mach3 parallel port or USB?
    By woodman08 in forum Mach Plasma / Laser
    Last Post: 07-13-2010, 10:27 PM
  3. How to add a second parallel port in mach3
    By waleed alhadidi in forum Mach Software (ArtSoft software)
    Last Post: 05-30-2010, 03:45 AM
  4. Mach3 on Laptop without Parallel Port
    By Deviant in forum Mach Software (ArtSoft software)
    Last Post: 09-01-2009, 01:34 AM
  5. Mach3 and Parallel port
    By Me2 in forum Mach Software (ArtSoft software)
    Last Post: 01-28-2007, 11:38 PM
