586,391 active members*
3,170 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > Error EX 0296 (411) Magazine Servo Alarm
Results 1 to 14 of 14
    Aug 2012
    8
    I have done the Zero return adjustment for Error EX0296 (224).
    But it does not work on this one, So I'v been searching the website for information on (411) after the EX0296. And I have come up empty.
    I would really appreciate if any one can help me figure this out.
    Thank you.
    Feb 2009
    6028
    Re: Error EX 0296 (411) Magazine Servo Alarm
    Might really help to know what machine we are talking about. I'm guessing its a horizontal with that alarm?
    Aug 2012
    8
    Sorry about that, Yes it is a horizontal. Mori Seiki SV-400, the servo amplifier unit is flashing *U and II*
    Feb 2009
    6028
    Sv is a vertical. Sh-400? It makes a difference since the horizontals use a Fanuc power mate for the magazines, most of the verticals don't.
    Aug 2012
    8
    Yes your right it is a vertical my apologizes
    Feb 2009
    6028
    Is this a Fuji drive on this one, or a schnieder?
    Aug 2012
    8
    The drive is Fanuc and the servo amplifier unit is Fanuc
    P/N A06B-6093-H152
    EA7700258
    Feb 2009
    6028
    Ok, see if you have PMM listed when you press the system key. Some machines had the power motion manager (pmm) and would let you look at diagnostic bits for the ATC through that.
    Aug 2012
    8
    Yes, this machine does have the PMM list
    Feb 2009
    6028
    Ok, let me find the parameter for zero return. if the machine won't let you set it normally, you can lie to it and set zero where it is, then index the magazine to #1 and toggle the bit.
    Aug 2012
    8
    OK thank you.
    Aug 2012
    8
    I figured out the reason the magazine servo motor was not rotating CHIPS got in between the gears and it was gamed up, cleaned it up did the zero return and and it was all good.
    Thank you for the help.
    Oct 2014
    28
    Can you detail me about machine system and take photo the 1815 parameter?
    Oct 2014
    28
    Can you detail me about machine system and take photo 1815 parameter?
  1. Replies: 27
    Last Post: 02-09-2022, 05:10 PM
  2. Error EX 0296 (411) Magazine Servo Alarm
    By Luis V. in forum Mori Seiki Mills
    Last Post: 10-18-2014, 03:49 PM
  3. fanuc alarm 1002 magazine stop error
    By Nevronplastics in forum Fanuc
    Last Post: 07-26-2012, 04:57 PM
  4. Error 414 Z axis error detect- servo alarm
    By andywids in forum Fanuc
    Last Post: 07-09-2009, 04:33 PM
  5. Error 414 Z-axis error detect servo alarm
    By andywids in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2009, 03:56 PM
