586,409 active members*
2,961 visitors online*
Thread: V27 Lockup
    May 2013
    701
    V27 Lockup
    V27: I have the automatic save set at 3 min and if auto save pop up window opens when I have a Features window open it locks up. I have had this problem in past version and has been a topic in the forum in the past . I was hoping this had been addressed. I guess its back to the remember to manually save save save.
    Experimenting with it more and it seems like it happens when I select a Feature option simultaneous when it automatically saves.
    Could someone maybe set the save to auto at low intervals and see if it is happening for you also?. (on something you don't care about)
    RAF.
    Apr 2009
    3376
    Re: V27 Lockup
    I manually save in V26.I figured it is a problem with wimpy computer and a case of the flu.Only demo in V27.
    Jun 2008
    1838
    Re: V27 Lockup
    It`s been doing that since V23, BC been told about it numerous times over the past 3 or 4 years. no fix as yet
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Dec 2011
    295
    Re: V27 Lockup
    Bob will lock if you manually save when its trying to figure something out also. Often Bob will create an open file and call it bobcad1. It will auto save that with nothing in it and that will wad the program while you have something in que. Slow your auto save down and close 'bobcad1.bc'.
  1. V26 LOCKUP
    By RAF. in forum BobCad-Cam
    Last Post: 10-03-2014, 05:48 AM
  2. Hurco MD1 Ultimax 2 control lockup
    By rallyslag in forum HURCO
    Last Post: 10-09-2010, 05:00 PM
  3. 1240 Smithy axis lockup issue
    By jeff 888 in forum Smithy
    Last Post: 09-22-2010, 04:48 PM
  4. Bobcad lockup
    By tsutt in forum BobCad-Cam
    Last Post: 10-23-2007, 01:17 AM
  5. Help..4aupc motor won't lockup.
    By Calico in forum Hobbycnc (Products)
    Last Post: 05-08-2005, 11:02 AM
