586,409 active members*
2,959 visitors online*
Results 1 to 10 of 10
    Will the Electronics Kit 4.3 Work With Linux?
    G'Day Folks,
    My name is Mike and I am a newbe to CNC routing. I live in Australia and this is my first post about my first machine.
    I just got this kit:
    Electronics Kit 4.3 OR CNC Router Electronics Kit 4.3 - 3 Axis 417oz / Hobby CNC Australia
    My question is - Will this electronics kit, which seems to be setup for Mach3, run on linuxcnc (EMC)? I have linux ubuntu and linuxcnc setup on my desktop but do I need to return it to Windows 7 to suit this kit? Anything you can add would help a lot please?
    Mike
    Mar 2004
    1661
    Re: Will the Electronics Kit 4.3 Work With Linux?
    Yes, you can run this kit with Step/Dir in LinuxCNC.
    It is the most used setup and is very easy to setup, use the Stepconf wizard and the Wiki documentation and you are up and running in no time.
    Stepper Configuration Wizard
    Thank you. Now I know where to start. Mike
    Jul 2014
    51
    That's one hell of a good deal. The Chinese can't sell it cheaper.
    And, Bob is a very nice helpful bloke. He takes the time to write long emails to help out. Mike
    I want to add it is a great kit for Australians but the shipping cost overseas would kill the benefits.
    Dec 2007
    2134
    Hi Mike,
    The steppers in that kit really need around 96VDC to run at full speed and torque, so with a 36VDC PSU, you'll need to lower the feed and rapid rates so the really high inductance doesn't kill the torque. The way to work out what rating PSU is needed is ((square root of the inductance) times 32).
    Apart from that, very good pricing on the kit, especially as it's much more complete than most you see.
    cheers, Ian
    Mar 2004
    1661
    Quote Originally Posted by aarggh View Post
    Hi Mike,
    cheers, Ian
    But the drivers are max 48 V though.
    Dec 2007
    2134
    Quote Originally Posted by svenakela View Post
    But for some reason the kits supplied with a 36VDC PSU! It would be worth changing the PSU to a 48VDC one IMHO.
    cheers, Ian
    Mar 2004
    1661
    cheers, Ian
    True that!
  1. linux emc work with Rorze?
    By bruno meola in forum LinuxCNC (formerly EMC2)
    Last Post: 12-16-2015, 11:01 PM
  2. Need help getting parport to work, works fine under linux.
    By CptanPanic in forum Mach Software (ArtSoft software)
    Last Post: 07-29-2012, 02:59 PM
  3. work linux EMC with Syil SX3 converse?
    By ata in forum LinuxCNC (formerly EMC2)
    Last Post: 04-28-2009, 06:53 PM
  4. Does Xylotex Board Work With Emc (linux)?
    By Hombre Verde in forum Xylotex
    Last Post: 02-01-2007, 07:06 AM
  5. What electronics/software work best for plasma?
    By JTH in forum Waterjet General Topics
    Last Post: 01-15-2007, 11:54 PM
