586,655 active members*
3,042 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Gears Module not allowing pitch change when in diametral pitch mode
    Nov 2006
    116
    I have been trying to use the gear module with no success. The software seems to be locked
    to a diametral pitch of "8" and will not allow me to change it. I can change the pressure angle
    and number of teeth but thats it. If I switch to module units I can change the pitch of the gear
    but when I switch back to "Diametral" the pitch is locked to the diametral equivalent of the pitch
    I set when in "Module" mode. This seems to me to be a problem in the software.
    Don
    Sep 2013
    326
    Re: Gears Module not allowing pitch change when in diametral pitch mode
    Quite a number of views w/ no reply! Have you sent a note over to the UK support side as well as the US side of Dolphin? I hope you get your answer? CG.
    Feb 2007
    414
    Hello,
    My apologies - I did see this but forgot to reply, there does seem to be a problem when you enter the diametral pitch, there is work around that you can use right now while we get this fixed.
    You can enter the module with this formula - Divide 25.4 by the Diamteral Pitch
    Hope this helps.
    ATB
    Andre
  1. 20 pitch VS. 16 pitch on a R&P system
    By i_r_machinist in forum Linear and Rotary Motion
    Last Post: 04-17-2013, 10:14 PM
  2. TOS SU 100 Pitch?
    By Fabio1 in forum Mach Lathe
    Last Post: 09-26-2012, 12:38 PM
  3. Leadscrew pitch is .1 max IPM??
    By Dan911 in forum DIY CNC Router Table Machines
    Last Post: 09-18-2011, 12:02 AM
  4. 530 pitch sprocket
    By juniormachinist in forum Solidworks
    Last Post: 05-13-2011, 10:55 AM
  5. 14.5 vs 20 deg pitch rack
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 05-30-2010, 05:27 PM
