586,129 active members*
3,076 visitors online*
Results 1 to 9 of 9
    Sep 2006
    31
    Axis won,t reset on Fanuc O-MC
    According to the manual I should be able to reset the relative and absolute positions to zero by going to the appropriate sceen, keying in the selected axis addresses to make them blink and pressing cancel to reset them. When I attempt this, the adresses don't blink. Can anyone help?
    Thanks.
    May 2006
    102
    You can't reset the absolute postion to zero other than by referencing. The relative you can reset by pressing X or Y or Z or all together and pressing cancel after reffing - any help?
    Sep 2006
    31
    Thanks for your reply. That's been tried with no luck. I think I may have bigger troubles, When I go into MDI and attempt to input G90, nothing happens when I press the "G" key. when I then press the "9" key the g appears on the screen. I'm befuddled.
    May 2006
    102
    off the top of my head that sounds like somebodys been 'effing with the parameters..
    May 2006
    102
    Hang on. The G key is the 9 key (at least on mine)
    24221
    You can have two keypads on the 0, called Standard or Full, they are set by P38.3 ****X*** (1-Full 0=Standard).
    Al.
    May 2006
    102
    Doh! yeah!(chair)
    and I thought it was a trick question
    Sep 2006
    31
    That's it! Thanks All.
    Sep 2007
    I need to install/set axis reference for alfa 0c wire edm recently shifted to our shop.
