586,525 active members*
3,353 visitors online*
Results 1 to 3 of 3
    Jan 2015
    1
    High Speed Scribing
    This is my first post so please go easy on me :cheers:
    I want to use our Multicam router to mark stud placements on the backs of aluminum letters.
    In the past, I would gently touch the material with my endmill to leave a swirl to mark the stud placement but unfortunately, my new company cannot do that. We have an 8' x 20' routing table but because the vaccuum is poor, we must use peg boad as a soil board and cannot level the table (also, there is no debris removal as well). Without the precision of a level table, lightly touching the material is not an option.
    I was thinking of two options: Using an engraving tool or using a scribe tool (some kind of spring-loaded punch).
    Using the engraving tool may work through the aluminum on the high table spots without much damage or mess. The scribe tool would work like a sharpie but the marks would last, however I am concerned with the horrizontal torque breaking the tool.
    Any experiences with marking aluminum or techniques to share? I would like some solid ideas before purchasing the parts.
    Thanks!!
    Jan 2007
    206
    Re: High Speed Scribing
    Go to Dorian Tool International they have a CNC marker that installs in the spindle. you have a mounting bracket on bottom to hold different types of metal stencils or TYPE, it is spring loaded and you lower it to the part and then a little lower the spring loaded trigger sets off and imprints the form on the part.
    Good Luck
    The Farmer
    Jun 2010
    463
    Got a few questions for you?
    1. Why can't the router be leveled. Simply doing this would allow you to use a method you are able to easily do
    2. How large is your vacuum? 20 ft is a lot, but using peg board is allowing a large amount of vacuum lost.
  1. High speed spindle... how high?
    By jonesja2 in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2015, 04:37 PM
  2. Replies: 7
    Last Post: 12-07-2014, 03:23 PM
  3. Coupling ideas for high speed and high torque
    By Azalin in forum Benchtop Machines
    Last Post: 07-24-2014, 11:38 PM
  4. high speed machining (High RPM)
    By bucketbot in forum MetalWork Discussion
    Last Post: 06-14-2012, 09:34 AM
  5. High Precision, High Speed Bearings
    By mikeyg in forum News Announcements
    Last Post: 09-08-2009, 01:06 AM
